- RotM Winner
- Elite Member
- Boosted
- Logged
Yeah just slide that axle back in. I found it interesting myself how simple and easy pulling it out and putting it back in is. I wondered about marking it but it doesn't need to be aligned any kind of way.
Not an easy task bc of the tightness of everything for the rear turbo but its not super complicated either. Nice work.
Sent from my LM-G710VM using Tapatalk
