New SHO owner with problems
Started by My15SHO, June 29, 2020, 12:58:05 PM
My15SHO
When I was reading about this I saw a mention of "break in" oil. Is that necessary? Just use regular or synthetic?
TopherSho
The block if it has already been 'run in' will have had the oil changed and any break in lube will have been removed. I would not add any additives or break in oil once it is installed.  Just run synthectic 5-20 or 5-30 as required by the block... after say 2000 miles then maybe add in small amounts of ZDDP oil as your car beliefs require,  but for the initial 2000 miles dont mess with the break in process by adding other things besides really good oil.
Best 0-60 public road 4.35s
My15SHO
Car is back, new engine installed along with three pages of various parts and fluids (distilled water?) Seems to drive good, idles nice and quiet, one BIG difference..... i can hear the blow off valve, loudly. I never heard a peep out of it before, could that have been an issue? Are these 3.5's suppposed to have a loud BOV?
76fomoco
the Bov's (2) are on the cross tube in the center top of the motor. they dump back into the intake it runs front to back. if the hoses didn't get put back to the intake it will be very loud. Post a picture of your motor with the black engine cover off.
2013 PP AJP E30 160 TS, sp542 plugs, 3 bar, PPE catted DP's, GH IC, GH turbos, XDI-35, EPP hot and intake
Best 3-29-21  11.85 with 3000 DA
DA trap best 117.96
E30 = 492 whp, 536 wtq
E30+meth 498 whp, 539 wtq
TopherSho
Quote from: My15SHO on July 23, 2020, 05:20:02 PM
This can also occur if the Boost control solenoid is open/busted :  https://www.getoemparts.com/oem-parts/ford-turbocharger-boost-solenoid-bl3z9k378a?origin=pla&gclid=Cj0KCQjwjer4BRCZARIsABK4QeVREO4_5tRf11N-hQqT2YLbVw05NkZlj6fuItpfER6-4payI9AN7vAaAk0yEALw_wcB
My15SHO
#20
I got about 20 miles out of it before the "Charging system" set off the warning light, then the power steering went out intermittently, the a/c stayed at one speed, lane keep stopped working,  shifted funky, ended up with an orange wrench light and in limp mode literally as i turned into the dealership. Somehow i knew an entire engine getting reinstalled trouble free the first time around was wishful thinking. Oh well. Now its an F150 until they get it fixed. I was in an Ecosport for the past 6 weeks.
SM105K
My15SHO
#22
I suppose the logical path is the alternator / battery. I didnt own the car long enough to really notice the battery date, i would assume with the extent of the repairs done some form of battery diagnostic would have been done. I suppose one fuse or connector missed and the car runs the battery dead and it stops. The car drove great until that charging system light came on. It gradually went down hill as i drove back to the dealer which to me sounds like battery drain from a improper charging system, where the "improper" part is will be interesting. Although now that i think of it when starting i noticed it took a few more "turns" when pushing the button to start
SM105K
Quote from: My15SHO on July 25, 2020, 02:47:38 PM
These car eat batteries.  One day it will be fine, next day battery is donzo.
ridered74
Quote from: SM105K on July 25, 2020, 05:24:56 PM
My last one I noticed that the starter seemed a little slower than normal. Drove it for 45 minutes and was actually going to replace it before it died. Drove 30 minutes to stop at home to get tools to swap battery at the parts store, came out of the house and it would not turn over. Since batteries are cheap and being stranded is not, I will replace the battery from now on after it has seen two winters.
Gearhead E30 tune, Gearhead intercooler, LMS firestorm hpfp, catted downpipes, corsa catback, 160 degree thermostat, 3 bar map, upgraded AD trans mounts, MSD coils, Nitto 555R drag tires on front, AR924 wheels and BFG sport comp 2 summer tires on rear, and an EPP intake.
12.2479 @ 118.05 fastest trap
11.591 @ 114.89   fastest ET
jims2015
Quote from: ridered74 on July 26, 2020, 01:19:49 AM
Same as mine. At exactly 3 years from taking it off the showroom, it turned over slower than usual. Then the next start didn't happen.
2015 PP, Thunderstorm DP & CAI. AlkyControl, Livernois dyno tune
2019 Corvette C7 Z51 A8 No mods
76fomoco
Quote from: jims2015 on July 26, 2020, 03:09:39 PM
on 3rd battery and each is just like this^^^^^ one or two days with slow starting and it heads south fast!
DA trap best 117.96
My15SHO
I get the battery going dead and preventing starting, but after its started and running, why would the battery cause the issues i had? Am i too old school in thinking it runs off the alternator once started? That power is run thru the battery but does a bad battery not allow that? I suppose after it sitting in a bay for 6 weeks and its all put back together the battery could take a dump quick.
SM105K
Quote from: My15SHO on July 27, 2020, 01:58:25 PM
I chalk it up to one of the SHO mysteries.  My car completely freaked out when my battery started tanking.  The dash freaked out, my climate controls freaked out, my back up camera flipped upside down.
I replaced the battery and all those issues went away.
802SHO
I had to replace my battery after the first winter I started using a battery tender.  It never actually died but it was about to.  I took it out for a drive and put it back on the tender only the tender light stayed red for a couple days after which isn't normal.  New battery stayed on a tender as soon as I would park it in the garage.  Now I upgraded to a lightweight battery and that stays on a tender as well.  Maybe buy a battery tender....keep it full at all times.
