- Jr. Member
- Ecobooster
- Logged
Quote from: Chris_Flex on April 14, 2020, 06:42:40 PM
Well pretty sure my 8 day old XDI 35 HPFP has failed...I did a pull today and I felt the car bog thankfully I was pretty much home, I parked and at idle I'm only at .35MPa rear fuel pressure I took off a little up my drive way and at 1800rpm it maxed out at .45MPa also had a P0087 code.
I've had a similar issue however it was temp related. Below 37~38'degrees the desired output was at this lower .37Mpa range. Once the temp read higher all things were back to normal.
I was told it was a corrupt file. Different Tuner, but received an updated file. This was at the beginning of winter (Michigan), just ran the stock pump and lower tune.
Ported - Heads, EX manifolds, and turbine housings, GH - turbos, TQ, & IC, EPP intake and hotpipes w/Tial (11lbs), x35 spacer, MSD coils, PPE catted DP, Magnaflow exhaust, DW in tank, Livernois Hpfp, Fuel-IT e-sensor, AEM WMI, SHO trans cooler, Megan Coilovers, Retrofitted Headlights, TSW wheels
