January 25, 2021, 09:15:38 AM
Author Topic:  Set BDX Programmer troubleshooting  (Read 726 times)
Offline SuperPete
  • Full Member
  • Pennsylvania
  • -Given: 12
  • -Received: 106
  • SHO Kind of guy
  • Liked:
  • Likes Given: 0
« on: April 06, 2020, 07:14:37 PM »
I have BDX plugged to my car all the time and its mounted at the top of the windshield so I can monitor needed parameters. IT's set so it comes up when I start car and goes to sleep once car is shut down.
Most of the time it works, but about 3 out of 10 times it will not wakeup and stays black screen, if i press any button it says waiting for the signal, pretty much nothing works without unplugging it and plugging it back in.
Anyone with same issue? Fix?
2014 SHO, GearHead TUNNED /Powered by Matt Robinson
PPE Downpipes, GearHead Intercooler, AirAid Intake
XDI-35 HPFP @ E40,   MSD Coilpacks
MUSTANG DYNO: 426/446
Continental Extreme Contact 06 & Powerstop Z23 all 4 corners
Offline SM105K
  • IG @egocheckersho
  • Forum Supporters
  • Arizona
  • -Given: 1049
  • -Received: 1221
  • Thee Forum Cowboy
  • Liked:
  • Likes Given: 22
Re: Set BDX Programmer troubleshooting
« Reply #1 on: April 07, 2020, 08:59:08 AM »
My Livewire does the same thing.  I just unplug and re plug back in.  Problem solved.
"M" 2013 SHO PP | AJPTurbo E30 Tune | FS HPFP | Stock IC with Ice Water DIY Sprayer | PPE Downpipes | Custom Magnaflow Resonator | 3rd Cat Delete | Derale Upgraded Trans Cooler | Dicunzolo Gen2 Trans Mounts| EPP Noisemaker Eliminator | MSD Coil Over Plugs | SP-542's | UPR Dual Valve Catch Can | K&N Drop In | Power Stop Slotted and Drilled Rotors with Stock PP Pads | H&R Springs  | AVS Flush Deflector | 802SHO Custom Splitter | Duraflex Chin Spoiler | Curva Concept C7's | Continental DWS06 Extreme Contact Rubber |
On deck: | ATP Turbos | Custom Air to Water IC, Heat Exchanger, and Ice Box |
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13033
  • -Received: 4233
  • Liked:
  • Likes Given: 4
« Reply #2 on: April 07, 2020, 09:42:47 AM »
Buggy sleep mode?
Offline SM105K
  • IG @egocheckersho
  • Forum Supporters
  • Arizona
  • -Given: 1049
  • -Received: 1221
  • Thee Forum Cowboy
  • Liked:
  • Likes Given: 22
« Reply #3 on: April 07, 2020, 10:26:36 AM »
Buggy sleep mode?
It could be.  I also think is has to do with how long the car sits honestly.  When I was driving it every day it didn't happen.  However, if I keep it plugged in and don't drive it for a couple of days, it has an issue of "not waking up".  I haven't done any research into it, but I am pretty sure after x amount of time it completely turns off.
90% of the time I unplug my Livewire completely if I know I am not going to drive me car for an extended period of time.
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13033
  • -Received: 4233
  • Liked:
  • Likes Given: 4
« Reply #4 on: April 07, 2020, 10:30:11 AM »
Makes sense.  Thankfully never an issue with any of my OBDlink adapters, but prob good practice anyway to unplug.
Offline SM105K
  • IG @egocheckersho
  • Forum Supporters
  • Arizona
  • -Given: 1049
  • -Received: 1221
  • Thee Forum Cowboy
  • Liked:
  • Likes Given: 22
« Reply #5 on: April 07, 2020, 10:38:41 AM »
I started unplugging it after your recommendation.
Offline SuperPete
  • Full Member
  • Pennsylvania
  • -Given: 12
  • -Received: 106
  • SHO Kind of guy
  • Liked:
  • Likes Given: 0
« Reply #6 on: April 07, 2020, 11:09:53 AM »
My car is daily driver, I drive to work to lunch home and after work what ever, so my time of car off are between 5 min to overnight and I don't see specific pattern when it happens, sometime it happens over 10 min shut off, other times during lunch and overnight at some, so there is absolutely no pattern.
I do have to unplug, but it's annoying.
I know I am up to date on latest and greatest firmware.
Anyone else?
Offline SuperPete
  • Full Member
  • Pennsylvania
  • -Given: 12
  • -Received: 106
  • SHO Kind of guy
  • Liked:
  • Likes Given: 0
« Reply #7 on: April 07, 2020, 02:12:05 PM »
So I reached out to customer service, they offered me to send unit back for troubleshooting.
its kind of pain to undo the programmer from where its at and dig the cable out but why not.
I'll keep you updated.
* Recent Topics
2010 Ford Taurus Blower Motor Not Working
by mike.kupinski | Today at 09:06:13 AM
I have an odd issue with my 2010 Ford Taurus Limited.The Blower Motor ...
Exciting Announcement: The New SHO Club of America Website (SCOA) is Live!
by rsporter50 | January 24, 2021, 04:50:36 PM
Visit it at: https://www.shoclubofamerica.com/Rather than the two web...
Re: ATP Turbo Failure
by autobahn terror | January 24, 2021, 07:32:13 AM
Yeah, this is happening at the worst possible time. Lots going on in m...
Re: World record Flex 12.2 @110
by Kanajana | January 23, 2021, 05:23:20 PM
A belated congratulations on your run. That's one quick brick. :t...
Re: Bad plugs, bad gas, or clogged cats?
by SHOdded | January 22, 2021, 10:57:34 AM
Pull the pipes off the turbos, make sure there is no pooling oil.Sent ...
Re: Need to share with this group.
by SHOdded | January 22, 2021, 08:35:16 AM
May the worst be behind you and clear sailing ahead.Sent from my SM-N9...
Re: Mini review of new AD Dogbones
by avidmotion | January 21, 2021, 10:15:28 PM
Still loving the dogbones, do more then i thought. Would not go back.....
Re: General GMAX RS summer tires
by avidmotion | January 21, 2021, 09:39:00 PM
Yes! Over 30,000 hard driven daily driver race car miles. I rotated ev...
Re: Black Betty... My first AWD car!
by 4eyedconekiller | January 21, 2021, 04:33:09 PM
Nice SHO.Fun ride.Thanks!!...
Re: What did you do to your Taurus/MKS today???
by Macgyver | January 21, 2021, 02:11:16 PM
Looks sharp.Front chrome delete ?...
