May 29, 2020, 10:02:13 pm
Author Topic: Help with aftermarket bov epp hotpipes  (Read 268 times)
Offline Cole.C
  • Jr. Member
  • -Given: 116
  • -Received: 27
« on: April 04, 2020, 12:01:37 pm »
Need help Thought i might try asking here, installing some EPP hotpipes and with the aftermarket bovs vacuum line Mike said to tap into the brake booster line behind the throttlebody but in my car it is a hard plastic line most the way back(outlined in red)into a larger1/2" pipe (outlined in blue) with a much larger ID then 1/16th inch. I havent heard back from mike on whether i could tap into this line(outlined in green) in front of the intake it seems to be on the intake piping similiar to the brake booster line.  Any opinions on if its safe to do so or what anyone recommends would be appreciated! Thanks guys.
Offline Nova
  • Full Member
  • -Given: 61
  • -Received: 77
Re: Help with aftermarket bov epp hotpipes
« Reply #1 on: April 04, 2020, 12:37:14 pm »
Read this, its helpful and should answer the questions you have.
http://www.ecoboostperformanceforum.com/index.php?topic=9409.0
« Last Edit: April 04, 2020, 12:41:31 pm by Nova »
Offline Cole.C
  • Jr. Member
  • -Given: 116
  • -Received: 27
« Reply #2 on: April 04, 2020, 05:30:57 pm »
So do you know if i just cap off the oem recirculating bov inlets into the intake? Will i throw codes without a tune revision having just unplugged the oem bov sensors?
Thanks for the help!
Offline Nova
  • Full Member
  • -Given: 61
  • -Received: 77
« Reply #3 on: April 04, 2020, 06:29:23 pm »
Yes you cap the recirculation inlets with rubber leg tips from home depot. I'll link a YouTube video showing how to cap off the recirc inlets.
If I'm not mistaken you have to have the rear bov plugged in and zip tied off to the side so that it won't be just hanging by the wire, and the front bov doesn't need to be plugged in. In doing this it won't throw any codes and no tune is needed.
Sent from my SM-G986U using Tapatalk
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • New York SHO
  • -Given: 1932
  • -Received: 4057
« Reply #4 on: April 04, 2020, 07:51:38 pm »
1." inch OD silicone high temp caps are ideal. I would avoid the leg end caps as they are not suitable for high temps and will sooner than later fall apart. Z
https://www.mcmaster.com/caps/
https://www.ecoboostperformanceforum.com/index.php/topic,8616.0.html
https://www.ecoboostperformanceforum.com/index.php/topic,8616.75.html
« Last Edit: April 04, 2020, 09:47:43 pm by ZSHO »
Offline FiveLeeter918
  • Ortiz Performance - Technical Sales
  • Vendor
  • Sr. Member
  • Tulsa, OK
  • -Given: 14
  • -Received: 228
  • Bewsted SHO
    • Ortiz Tuning and Performance
« Reply #5 on: April 17, 2020, 12:52:32 am »
I prefer the TurboSmart Boost Reference Adapter, it goes under the MAP sensor on the intake manifold and it's a much cleaner install IMHO.
https://www.ortizperformance.com/product-page/turbosmart-boost-reference-adapter-2010-3-5l-ecoboost-black
And I personally had chair caps for 2 years before the EPP dual intake and never had an issue. I replaced them twice just out of peace of mind but never leaked.
- Lee
* Recent Topics
SCOA Official Member!!!
by StealBlueSho | Today at 08:27:11 pm
Got my stuff today from Ron Porter!!! Totally awesome! He received 100...
Re: Ranger Performance Tune From Ford
by SHOdded | Today at 07:45:46 pm
Since Ford wants to provide a warranty with the tune, they are not gen...
Re: 2016 Black SHO from Mi
by SHOdded | Today at 07:43:17 pm
Getting the foundation strong is never a waste of time....
by StealBlueSho | Today at 04:20:55 pm
Well I said bye bye to the noisemaker.  Bought an Explorer Sport ...
Re: What size filter sock/cover for EPP gen 2 dual filter?
by StealBlueSho | Today at 01:06:50 pm
I used Part Number: 20-1770 for my original version Gen 1 intake and f...
Back to top
