April 02, 2020, 03:16:51 AM
Author Topic: Epp hot pipes air intake help  (Read 261 times)
Offline Nova
  • Full Member
  • -Given: 45
  • -Received: 62
« on: March 26, 2020, 03:43:43 PM »
I'm currently installing my epp dual feed intake and hot pipes and I'm stuck!! I can't figure out how to remove the rear turbo hose so that I can install the new "s" silicone hose that comes with the kit. I can feel the hose clamp and I can see it from underneath the car but I can't get a socket up from underneath the car.
If you have any advice, please let me know!!!
Sent from my SM-G986U using Tapatalk
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • : New York SHO
  • -Given: 1891
  • -Received: 3978
Re: Epp hot pipes air intake help
« Reply #1 on: March 26, 2020, 03:57:55 PM »
Remove the rear hose from the TOP of the motor with a 8mm or 7mm socket IIRC and Preferably a 1/4 ratchet and swivel extender combo. When loose try pulling and twisting the hose off by hand. Z
« Last Edit: March 26, 2020, 04:05:00 PM by ZSHO »
Offline Nova
  • Full Member
  • -Given: 45
  • -Received: 62
« Reply #2 on: March 26, 2020, 04:02:49 PM »
Remove the rear hose from the TOP of the motor with a 8mm socket and Preferably a 1/4 ratchet snd  swivel extender combo. Z
I tried for awhile then I uninstalled the bov pipe to the rear turbo to give me more room but I still couldn't get to it. So I jacked the car up and I can see the clamp from underneath and wherever I put a socket to it the clamp is too close to the turbo so the socket is hitting the side of the turbo and not giving me a good attachment to the clamp bolt.
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • : New York SHO
  • -Given: 1891
  • -Received: 3978
« Reply #3 on: March 26, 2020, 04:09:25 PM »
I would try to use a long flat head screw driver and try to push the hose clamp until accessible. Z
Offline Nova
  • Full Member
  • -Given: 45
  • -Received: 62
« Reply #4 on: March 26, 2020, 04:11:09 PM »
Thanks Z! I'll try again in the morning because I had to stop and take a break before I broke something.
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • : New York SHO
  • -Given: 1891
  • -Received: 3978
« Reply #5 on: March 26, 2020, 04:38:21 PM »
Both Hose clamps should be facing towards the TOP of the engine from the factory.. Best of luck and keep us updated. Z
Offline Nova
  • Full Member
  • -Given: 45
  • -Received: 62
« Reply #6 on: March 26, 2020, 05:23:59 PM »
Clamp #1 is facing up but clamp #2 is facing down
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • : New York SHO
  • -Given: 1891
  • -Received: 3978
« Reply #7 on: March 26, 2020, 06:57:35 PM »
True! But accessed both clamps for turbo and charge pipe from up Top without a hitch. Z
« Last Edit: March 26, 2020, 07:00:20 PM by ZSHO »
Offline ridered74
  • Full Member
  • -Given: 71
  • -Received: 96
« Reply #8 on: March 26, 2020, 10:04:19 PM »
Mine was facing straight down. Impossible to get to from above.
Firestorm hpfp, catted downpipes, Corsa catback, 160 degree thermostat, 3 bar map, Gearhead E30 tune, Gearhead intercooler and upgraded trans mounts.
12.2479 @ 118.05 fastest trap
11.7513 @ 117.04   fastest ET
Offline Chris_Flex
  • Full Member
  • : Lancaster,PA
  • -Given: 39
  • -Received: 78
« Reply #9 on: March 27, 2020, 04:51:54 AM »
I had to do mine from underneath with a 1/4 ratchet and long extension and swivel, my clamp was facing down then I installed the new coupler and clamp from the top just with feel
2013 Ford Flex Ecoboost
BC Coilovers
Trans mounts
Unleashed e30 Tune
Offline 6500rpm
  • Quality Always Shoots Straight
  • Full Member
  • : the safe zone just outside St Louis
  • -Given: 39
  • -Received: 89
« Reply #10 on: March 27, 2020, 08:10:13 AM »
Mine was facing  down as well. I used a long flat blade screw driver at a bit of an angle to get on it. Once you start to get it loose you can move it around a bit to finish up. Make sure you put a bit of lube on the new coupler when going back on. As a practice I never do that but I found it a must on this. I never figured out why, but a week or so later I had a 19 non PP on my lift at work and it seemed like that area on the rear turbo was wide open as compared to my 13 PP. That brings up another  point, if you're working on  jackstands, get them as high as possible to buy yourself some working room.
« Last Edit: March 27, 2020, 09:28:49 AM by 6500rpm »
2013 SHO PP in Ruby Red Metallic, GTG Billet Grills, Duraflex Racer Chin Spoiler, DriveBright LED Driving/Turn Lights,160 T Stat, MSD Coils, All Royal Purple Lubricants, EPP Gen 2 Duel Intake and hotpipes
Offline Nova
  • Full Member
  • -Given: 45
  • -Received: 62
« Reply #11 on: March 27, 2020, 08:16:17 AM »
I have an 18 and I wish mine was wide open.
Offline Nova
  • Full Member
  • -Given: 45
  • -Received: 62
« Reply #12 on: March 28, 2020, 02:24:55 PM »
Finally got everything installed! That clamp was a big B!!! I had to use a 12" flat head screwdriver from underneath the car, but once i got that stupid clamp out it was smooth sailing until it came to installing the air box, filter and the 2 pipes that go into the air box. I looked at other people's pictures of their install and they were able to get the ckamps on the outside of the box but I couldn't do that cuz the pipes would only go so far into the filter so I had to clamp them inside of the box. Everything is solid and doesn't move so I guess it'll work.
I took it for a little test drive and i can hear the turbos spooling up and I love the sound of the bov! This is my 1st turbo car so I have been driving around and letting off the gas just so I can hear the bov's. The car feels like it pulls harder but that could just be in my head.
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • : New York SHO
  • -Given: 1891
  • -Received: 3978
« Reply #13 on: March 28, 2020, 04:47:56 PM »
It looks Great there NOVA! :thumb: Glad you got it sorted out. The configuration on the Gen 2 EPP Dual intake is a bit different compared to the original Gen 1 IIRC! Enjoy. Z
« Last Edit: March 28, 2020, 04:55:11 PM by ZSHO »
Offline Nova
  • Full Member
  • -Given: 45
  • -Received: 62
« Reply #14 on: March 28, 2020, 05:24:56 PM »
Oh so you have a gen 1 intake? I was using your pictures as reference during my install.
* Featured Topics
* Recent Topics
by Nova | April 01, 2020, 10:28:01 PM
Installed LED's in the turn signals. Next I'm going to switc...
by fordfanstan | April 01, 2020, 09:10:28 PM
I just bought a pair of Catted PPE DP's from Vivid Racing for ano...
Re: Deatschwerks DW300C Fuel Pump Updates for 2013+ SHOs
by aresix6 | April 01, 2020, 08:43:05 PM
So I've got an XDI HPFP-60 along with their upgraded +50% injecto...
Re: B1086- Air Distribution Damper Motor - Panel/floor/defrost not working
by ZSHO | April 01, 2020, 04:14:20 PM
FYI- Both Topics were merged together for added convenience. Be well. ...
Re: New recommended spark plug
by StealBlueSho | April 01, 2020, 03:34:59 PM
https://performanceparts.ford.com/part/M-12405-35T...
Re: Buying Explorer Sport - mod help
by Gjkrisa | April 01, 2020, 10:28:38 AM
I was aiming for a 2016+ for sync 3 Sent from my Pixel 4 XL using Tapa...
by Dannymack | March 31, 2020, 12:57:03 PM
Pretty happy with how aggressive this thing looks so far. Especially c...
Re: New Bro
by SHOstopper | March 30, 2020, 01:55:38 PM
So my hombre is a wizard and this is the finished product. I couldn�...
Re: leak in rear windshield ?
by ZSHO | March 30, 2020, 01:05:45 PM
Fingers crossed for ya! Z...
Re: F150 Boost pressure feels limited
by Defhd10 | March 30, 2020, 10:46:51 AM
The Dealership did it.  It most likely corrupted the ECU with the...
by StealBlueSho | March 29, 2020, 04:45:29 PM
https://uploads.tapatalk-cdn.com/20200329/667e0cfc909d60d4096ca5aa46f0...
Re: 2013 Ford Edge SEL 2.0 EB Transmission Relearn Process:
by SHOdded | March 29, 2020, 03:55:50 PM
Not many Edge owners on here, not active anyway.Forscan Lite has a TCM...
Re: Ethanol analyzer
by WinPlaceSHO | March 29, 2020, 01:44:32 PM
Ok, my "Google-Fu" wasn't working yesterday, but I fina...
Re: SCT Friday Flash Sale, Today only 3-27-2020
by tmcphail | March 29, 2020, 10:45:55 AM
Sale has been extended to the 31st !https://mailchi.mp/unleashedtuning...
Re: NEED HELP: Changing PTU oil on Performance Package PTU
by SuperPete | March 29, 2020, 07:17:10 AM
Yep Yep......
Back to top
