March 28, 2020, 11:36:53 AM
Author Topic: Stock turbo efficiency..?  (Read 117 times)
Offline StinkinLinkin13
  • Full Member
  • : San Antonio, Texas
  • -Given: 50
  • -Received: 137
  • Ecoboosted
« on: March 19, 2020, 06:59:17 PM »
Ok. Hate to be this guy. I'm sure its been discussed before. But how much boost can the stock turbos deliver efficiently... I know ATP is the upgrade option but my turbos are new and I have no plans on upgrading anytime soon. So where these stockers gonna max out?
2016 Lincoln MKS Ecoboost -
Livernois Catless downpipes with Magnaflow mufflers - Livernois E85 tune - Firestorm HPFP - 3 Bar Map - Alky Controls Meth Injection - 160 Thermostat - EPP Hot Pipes - AEM Dryflow Filter - BOV VTA - SSM Polyurethane Torque Struts - H&R Sport Springs - 20"x10" Niche Veronas on 275/40-20 DWS06 -
Offline SHOdded
  • Administrator
  • : Beltsville, MD
  • -Given: 12687
  • -Received: 4160
Re: Stock turbo efficiency..?
« Reply #1 on: March 19, 2020, 08:47:04 PM »
IIRC, 16-18 psi is the "hot zone" for these tiny turbos.  They have been driven to 23-24 psi during spikes, but ...
Offline Gjkrisa
  • : Fairbanks, AK
  • -Given: 960
  • -Received: 211
    • Photos
« Reply #2 on: March 19, 2020, 09:01:10 PM »
Do we know airflow numbers for any of these turbos?
Offline 802SHO
  • : Essex Junction Vermont
  • -Given: 2019
  • -Received: 975
  • Boosted
« Reply #3 on: March 20, 2020, 03:01:16 AM »
Don't forget, GearHead is the other upgrade option.  You can see how efficient they are by datalogging your wastegates duty cycle %.  If you're @ 19 psi and WGDC is 100% they're maxed.
2010 SHO non PP, GH upgraded turbos, GH upgraded IC, EPP Hot Pipes, Alky Control Methonal Injection, Alky dual nozzle upgrade, Zex Nitrous, Dicunzolo Gen2 torque mounts, SP542 .028, 160 T, Airaid Intake, 3bar, Thunderstorm Catless Downpipes, custom stainless 2.5" double xpipe w/muffler deletes 4" quad tips, UPR Dual Valve Catch Can, Derale 10000 series 16 row trans cooler, 13+ PP Trans Cooler, Econoaid throttle Body Booster, Mickey Thompson 20x9 SC-5 Wheels, Continental Extreme Contact DW tires F: 245/40/20 R: 275/35/20, H&R Springs all around w/rear cut 1/2", 1" hubcentric wheel spacers m14 1.5 stud/lug conversion, Aeroforce Interceptor Gauge, Tuned by AJP Turbo
Highest Trap Speed 123.22 mph
463awhp 569 awtq mustang dyno 6/13/19
PB 11.368 @ 122.68 NED 10/20/19
Offline 802SHO
  • -Given: 2019
  • -Received: 975
  • Boosted
« Reply #4 on: March 20, 2020, 03:56:07 AM »
Matt Robinson shared flow data a while back of stock turbos vs his upgraded ones.
* Featured Topics
* Recent Topics
Re: NEED HELO: Changing PTU oil on Performance Package PTU
by SuperPete | Today at 11:33:10 AM
Thank you, but the issue is that he drilled his own drain plug hole on...
Re: SuperPete SHO Build record
by SuperPete | Today at 09:55:42 AM
Yes, two clams were lose AND, i was reading forum about throttle body ...
Re: BBK 3.5L/3.7L V6 70MM THROTTLE BODY for 10-19 SHO/FLEX/MKS
by Jordan | Today at 05:21:26 AM
I've never heard of anybody having issues on the stock throttle b...
Re: How To Clean A Foggy Rear View Camera
by Jordan | March 27, 2020, 04:27:30 PM
I need this in my life. Maybe I will do it tomorrow! Mines been grimy ...
Re: F150 Boost pressure feels limited
by TopherSho | March 27, 2020, 11:14:11 AM
NP!  ...
Re: Epp hot pipes air intake help
by Nova | March 27, 2020, 08:16:17 AM
Mine was facing  down as well. I used a long flat blade screw dri...
SCT Friday Flash Sale, Today only 3-27-2020
by tmcphail | March 27, 2020, 07:49:05 AM
SCT X4 or BDX $ 399 shipped with One Custom Tune. Free Shipping offer ...
by Dannymack | March 27, 2020, 07:00:12 AM
To continue with the painting.Next were the badges. Matching those up ...
by Dannymack | March 26, 2020, 08:57:06 PM
Cleaned up the foggy rear view camera. Trying to do as many low cost p...
by ZSHO | March 26, 2020, 07:02:37 PM
Thanks for the kind words from ^^^  :)  Bit of creativity go...
Re: New Bro
by SHOstopper | March 26, 2020, 11:24:58 AM
Quick preview from my hombre at the body shop of new trim color...
Re: JMS vs Kenne Bell Boost a Pump.
by StinkinLinkin13 | March 26, 2020, 07:57:40 AM
Its an electric fuel pump. I placed order a day ago. Hopefully gets sh...
Re: Friction modifier in rear end
by nickstewartroc | March 25, 2020, 06:20:21 PM
As far as the half shafts being small, keep in mind with the torque co...
Re: leak in rear windshield ?
by ZSHO | March 25, 2020, 05:57:52 PM
Drain hose routing 2014http://www.nicksmustangranch.com/Service_Manual...
Re: Carter HPFP 2900 psi
by FiveLeeter918 | March 25, 2020, 05:10:44 PM
Reached out to carter today. Unfortunately there 2900 psi pump is for ...
Back to top
