September 26, 2020, 04:01:33 AM
Author Topic:  Duel injection washing effect vs methanol-a real life look (Meth pictures wanted  (Read 5050 times)
Offline 6500rpm
  • Quality Always Shoots Straight
  • Full Member
  • the safe zone just outside St Louis
  • -Given: 51
  • -Received: 110
  • Liked:
  • Likes Given: 4
Fleet work brings almost all every make my way, all vehicles under 2 years and most under 40,000mi. The one thing that I've seen across all makes (some worse than others) is intake valve coking on DI engines. Unfortunately I haven had a opportunity to check my SHO yet, but I did a engine replacement on a 2019 5.0L Mustang GT this week that runs the Duel Injection (DI +Port) and the proof is in the picture. This engine had 28,000 miles on it when it took it's last breath but take a look at the intake valve-absolutely spotless!
If any of you guys running methanol have picture stored of your intake valves or get a chance to in the future, please post up. I'd really like to see if the cleaning effect of the methanol is anywhere close to what I'm seeing on the new dual injection cars. I'm on the fence about adding methanol based on my daily driving needs, but if it's the only thing we have that's close to duel injection for our platform and if it's even close I'm in.
Offline ZSHO
  • Forum Supporter
  • Forum Supporters
  • New York SHO
  • -Given: 1939
  • -Received: 4077
  • Liked:
  • Likes Given: 0
Great Topic indeed!  :)  I would @ the very least add an OCC to the mix if your concerned about Blow-by since the DI are prone to run dirty..  Adding some GDI intake cleaner via intake Plenum @ every 24k mile interval in conjunction with some BBK or Chevron with techron fuel system cleaner @ every oil change would certainly be ideal. Need to get a boroscope to see what actually is going on inside the internal combustion chamber! I will certainly post pics once I gain access to a boroscope..
I have been side-lined with some sort of viral bug for quite some time now.  :(
But in the meantime Thanks for your contribution. Z
« Last Edit: February 13, 2020, 06:22:16 AM by ZSHO »
Offline SM105K
  • IG @egocheckersho
  • Forum Supporters
  • Arizona
  • -Given: 1036
  • -Received: 1198
  • Thee Forum Cowboy
  • Liked:
  • Likes Given: 13
I am pretty sure that BPD has pictures of his valves when he had his motor torn down.
"M" 2013 SHO PP | AJPTurbo E30 Tune | FS HPFP | GH Intercooler w/ DIY Ice Water IC Sprayer | PPE Downpipes | Custom Magnaflow Resonator | 3rd Cat Delete | Derale Upgraded Trans Cooler | Dicunzolo Gen2 Trans Mounts| EPP Noisemaker Eliminator | MSD Coil Over Plugs | SP-542's | UPR Dual Valve Catch Can | K&N Drop In | Power Stop Slotted and Drilled Rotors with Stock PP Pads | H&R Springs  | AVS Flush Deflector | 802SHO Custom Splitter | Duraflex Chin Spoiler | Curva Concept C7's | Continental DWS06 Extreme Contact Rubber |
Offline bamsho
  • south williamsport, pa
  • -Given: 224
  • -Received: 531
  • Liked:
  • Likes Given: 24
His valves are pretty close to those pictured.  I need to scope my motor to look at mine.  I've sprayed more meth than Mike due to my track time.
Offline HD-Rugby
  • Jr. Member
  • SE PA
  • -Given: 59
  • -Received: 5
  • Liked:
  • Likes Given: 2
OCC? Recommendation? I think I know where the intake Plenum is but what GDI cleaner would you recommend. Iíve got Sea Foam spray but I do spray and 50-50 mix of seafoam and water into my carburetors for my Harleysís. It does a nice job on the valves and everything else... I have to run them rich because itís high compression and an air cooled motor. Thank You Sir
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13013
  • -Received: 4215
  • Liked:
  • Likes Given: 0
JLT has become pretty popular with Ecoboost lovers lately, so worth a look.  Or UPR.  Or build your own with kits found on Amazon, eBay, and the like.
Offline ZSHO
  • Forum Supporter
  • Forum Supporters
  • New York SHO
  • -Given: 1939
  • -Received: 4077
  • Liked:
  • Likes Given: 0
I had the Ford dealer perform an induction system cleaning many years ago using Valvoline VPS 2 Part fuel Kit due to a rough idle for $99.00 IIRC..
They recommended this procedure every 24K part of a routine preventive maintenance against early stages of carbon buildup..
I would not recommend having this procedure performed on high mileage vehicles IMHO and don't need debris of carbon entering the turbo fins and should use at your own risk. Z
https://www.valvoline.com/recommended-auto-services/fuel-and-air
https://www.autocarevideo.com/video/valvoline-easygdi-how-to-perform/
« Last Edit: February 14, 2020, 07:55:40 PM by ZSHO »
* Recent Topics
Re: BamSHO 12.14 MIR Extra Preppy!!
by bpd1151 | September 25, 2020, 10:27:57 PM
Sucky sucky, licky licky. Brian you filthy, slutty hoe.Sent from my SM...
Re: SHO vs Hellcat Redeye
by bamsho | September 25, 2020, 09:32:46 PM
What rims and tires are you running on the fronts?  You gapped hi...
Re: Need inexpensive tires for my 2013 SHO
by avidmotion | September 25, 2020, 08:19:45 PM
https://simpletire.com/brands/general-tires/g-max-rs#v=1&tireSize=...
by GotGrip? | September 25, 2020, 04:24:56 PM
So I was watching this ocean show with my daughter on disney+ and it w...
Re: Whiteline 24mm Adjustable Rear Sway Bar for 2010-2019 Taurus SHO/MKS/Flex/MKT
by SHO_NVS | September 25, 2020, 02:32:21 AM
I'm in. PM sent...
Re: Water in passenger floor
by SHO_NVS | September 25, 2020, 02:28:51 AM
Oh man, glad you found it.  Hopefully that fixes it.  I live...
Re: Carbon hood install
by SHO_NVS | September 25, 2020, 02:23:04 AM
That looks nice! Good job!...
Re: Wheel pulls bad one way then snaps back
by SHO_NVS | September 25, 2020, 02:18:05 AM
Glad you found that loose bolt, crazy.  How do you like the down ...
Re: And the award for most frequently broken car goes to...
by Macgyver | September 24, 2020, 10:28:06 PM
Oh Boys. Lets hope she holds together !!!...
Re: Daily driver MKT
by TopherSho | September 24, 2020, 08:07:20 PM
:zumbujump: :zumbujump: :zumbujump: :zumbujump: :) :) :)Curious of op...
