May 27, 2020, 02:28:23 am
Author Topic: Duel injection washing effect vs methanol-a real life look (Meth pictures wanted  (Read 4451 times)
Offline 6500rpm
  • Quality Always Shoots Straight
  • Full Member
  • the safe zone just outside St Louis
  • Thank You
  • -Given: 44
  • -Received: 100
  • Ecobooster
Fleet work brings almost all every make my way, all vehicles under 2 years and most under 40,000mi. The one thing that I've seen across all makes (some worse than others) is intake valve coking on DI engines. Unfortunately I haven had a opportunity to check my SHO yet, but I did a engine replacement on a 2019 5.0L Mustang GT this week that runs the Duel Injection (DI +Port) and the proof is in the picture. This engine had 28,000 miles on it when it took it's last breath but take a look at the intake valve-absolutely spotless!
If any of you guys running methanol have picture stored of your intake valves or get a chance to in the future, please post up. I'd really like to see if the cleaning effect of the methanol is anywhere close to what I'm seeing on the new dual injection cars. I'm on the fence about adding methanol based on my daily driving needs, but if it's the only thing we have that's close to duel injection for our platform and if it's even close I'm in.
2013 SHO PP in Ruby Red Metallic, GTG Billet Grills, Duraflex Racer Chin Spoiler, DriveBright LED Driving/Turn Lights,160 T Stat, MSD Coils, All Royal Purple Lubricants, EPP Gen 2 Duel Intake and hotpipes
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • New York SHO
  • Thank You
  • -Given: 1932
  • -Received: 4056
Great Topic indeed!  :)  I would @ the very least add an OCC to the mix if your concerned about Blow-by since the DI are prone to run dirty..  Adding some GDI intake cleaner via intake Plenum @ every 24k mile interval in conjunction with some BBK or Chevron with techron fuel system cleaner @ every oil change would certainly be ideal. Need to get a boroscope to see what actually is going on inside the internal combustion chamber! I will certainly post pics once I gain access to a boroscope..
I have been side-lined with some sort of viral bug for quite some time now.  :(
But in the meantime Thanks for your contribution. Z
« Last Edit: February 13, 2020, 06:22:16 am by ZSHO »
Offline SM105K
  • Forum Supporters
  • Elite Member
  • Arizona
  • Thank You
  • -Given: 832
  • -Received: 1028
  • HATER MAKER
I am pretty sure that BPD has pictures of his valves when he had his motor torn down.
"M" 2013 SHO PP | AJPTurbo E30 Tune | GH Intercooler | PPE Downpipes | Custom Magnaflow Resonator | 3rd Cat Delete | Dicunzolo Gen2 Trans Mounts| EPP Noisemaker Elimintor | MSD Coils | SP-542's | UPR Dual Valve Catch Can | K&N Drop In | Power Stop Brakes | H&R Springs  | Curva Concept C7's | Continental DWS06 Extreme Contact Rubber |
"The Fukus" 2013 Focus ST | AJPTurbo Flex Fuel Tune | Megan Racing Catless Downpipe | Boomba BOV | FSWerks Short Shifter | Power Stop Brakes | Continental DWS06 Extreme Contact Rubber |
Offline bamsho
  • Elite Member
  • south williamsport, pa
  • Thank You
  • -Given: 171
  • -Received: 474
  • Ecobooster
His valves are pretty close to those pictured.  I need to scope my motor to look at mine.  I've sprayed more meth than Mike due to my track time.
Offline HD-Rugby
  • Jr. Member
  • SE PA
  • Thank You
  • -Given: 59
  • -Received: 5
  • Ecobooster
OCC? Recommendation? I think I know where the intake Plenum is but what GDI cleaner would you recommend. Iíve got Sea Foam spray but I do spray and 50-50 mix of seafoam and water into my carburetors for my Harleysís. It does a nice job on the valves and everything else... I have to run them rich because itís high compression and an air cooled motor. Thank You Sir
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 12953
  • -Received: 4203
JLT has become pretty popular with Ecoboost lovers lately, so worth a look.  Or UPR.  Or build your own with kits found on Amazon, eBay, and the like.
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • New York SHO
  • Thank You
  • -Given: 1932
  • -Received: 4056
I had the Ford dealer perform an induction system cleaning many years ago using Valvoline VPS 2 Part fuel Kit due to a rough idle for $99.00 IIRC..
They recommended this procedure every 24K part of a routine preventive maintenance against early stages of carbon buildup..
I would not recommend having this procedure performed on high mileage vehicles IMHO and don't need debris of carbon entering the turbo fins and should use at your own risk. Z
https://www.valvoline.com/recommended-auto-services/fuel-and-air
https://www.autocarevideo.com/video/valvoline-easygdi-how-to-perform/
« Last Edit: February 14, 2020, 07:55:40 pm by ZSHO »
* Featured Topics
* Recent Topics
by bpd1151 | Today at 01:21:26 am
I'm hoping that that opening line is laden with sarcasm.Actually ...
Re: Updated Gallery Capabilities
by bpd1151 | Today at 01:10:42 am
I have some time off from work coming up soon. I'll have to check...
by 10sleeper | Today at 12:43:07 am
Re: For those looking for something different for a 2nd (or 3rd) car
by FoMoCoSHO | May 26, 2020, 11:23:21 pm
There is another CON if you are a DIY type...The packaging is slick bu...
Re: 802SHO 2010 Build
by FoMoCoSHO | May 26, 2020, 11:08:36 pm
Pretty sweet upgrade for us Gen IV saps even without the porting.The e...
by Gjkrisa | May 26, 2020, 09:28:19 pm
I almost bought a dodge/jeep/Chrysler product once....nah I didn'...
by GhostlyGrenade | May 26, 2020, 07:35:35 pm
They must be giving SCT devices away. There's no way people are s...
Re: MRT blues
by StinkinLinkin13 | May 26, 2020, 04:32:36 pm
We'll my four muffler setup is a winner for me. Its not pretty ri...
Ecoboosted Gallery!!
by StealBlueSho | May 26, 2020, 11:27:31 am
by 802SHO | May 26, 2020, 05:15:44 am
Re: EBPF Under New Ownership!
Re: EPP CAI
Re: Letís talk weight reduction?!
Re: Ford Recalls
Re: Brake Cooling Kit
Back to top
