Jordan's Dyno Results
Started by Jordan, February 05, 2020, 05:03:01 PM
Jordan
StinkinLinkin13
I'm a little surprised. I actually thought the numbers would be higher considering your ETs and MPH. Just started working with AJP myself... See what happens. 🤙
Just out of curiosity. What time did you run on Gearheads tune?
Livernois Catless downpipes with Totalflow mufflers - AJP E40/Meth tune - Firestorm HPFP - DW 300 LPFP - Kenne Bell Boost-a-Pump - 3 Bar Map - Alky Controls Meth Injection - 160° Thermostat - EPP Hot Pipes - AEM Dryflow Filter - BOV VTA - SSM Polyurethane Torque Struts - H&R Sport Springs - 20"x10" Niche Veronas on 275/40-20 DWS06 -
Jordan
Quote from: StinkinLinkin13 on February 05, 2020, 08:26:41 PM
I haven't ever ran gh down the strip.
ridered74
Quote from: Jordan on February 05, 2020, 10:31:28 PM
Dang I must have missed the gearhead numbers when I looked on my phone.
FWIW I have same mods with GH E30 tune other than my pipes are catted and I don't have the dual intake, my best full weight run was 12.116 on a 90-95 degree day.
Gearhead E30 tune, Gearhead intercooler, LMS firestorm hpfp, catted downpipes, corsa catback, 160 degree thermostat, 3 bar map, upgraded AD trans mounts, MSD coils, Nitto 555R drag tires on front, AR924 wheels and BFG sport comp 2 summer tires on rear, and an EPP intake.
12.2479 @ 118.05 fastest trap
11.591 @ 114.89   fastest ET
802SHO
Awesome Jordan!  Now we will see what GH Turbos add!
Jordan
Quote from: ridered74 on February 06, 2020, 02:24:37 AM
GH absolutely put down some numbers, but never wanted to run it down the drag strip because while 3rd gear and above felt like money the launch with 1st and 2nd gear was always severely lacking. Goes to show numbers isn't everything. However I am eagerly waiting to work with both as I know both have their own tuning styles and I figure they both do sick jobs.
6500rpm
Jordan, are you not methanol injected? I was running through  your YouTube videos and the one one where the injector crapped out got my attention where you looked at the intake valve deposits. Your valves in general look fairly clean compared to a lot of DI engines that I've  worked on but I didn't see methanol on your list. I pulled a 5.0l out of a 2019 mustang GT today with the duel DI/port injection set up and you can really see the washing effect from the port injectors.
I just wanted to verify if you were spraying or not because with the exception of the one cylinder your valves really do look good by today's DI standards. Good luck this year, I know it's a  bit of a drive but I bet your times would be better at Gateway with the track prep.
2013 SHO PP in Ruby Red Metallic, GTG Billet Grills, Duraflex Racer Chin Spoiler, DriveBright LED Driving/Turn Lights,160 T Stat, MSD Coils, All Royal Purple Lubricants, EPP Gen 2 Duel Intake and hotpipes,3 bar, Gearhead AO tuned!
