September 26, 2020, 04:22:56 AM
Author Topic:  PTP Turbo Blankets  (Read 7091 times)
Offline 802SHO
  • RotM Winner
  • Essex Junction Vermont
  • -Given: 2353
  • -Received: 1133
  • Boosted
  • Liked:
  • Likes Given: 0
PTP Turbo Blankets
« on: January 31, 2020, 05:24:41 AM »
Turbo Blankets aid in keeping the turbo hotter, hotter air increases spooling and efficiency of the turbos.  Turbo Blankets also reduce under hood temps by containing the heat from the turbos to itself.  This increases responsiveness and enhances the power band.  In a test 6.7 Turbo Diesel engine, simply adding this PTP Turbo Blanket increased torque in the power band by 100ft lbs.  It didn't add peak torque but it released nearly 10% torque in areas where it wasn't previously available in the power band....impressive.
Aaron240 over at SHOFORUM recently sent PTP our turbo info and they are willing to create Turbo Blankets for our platform if there is enough interest.  Anyone else interested in this?
2010 SHO non PP, Tuned by AJP Turbo, Ported GH upgraded turbos, Ported 13+ Exhaust Manifolds, GH upgraded IC, EPP Hot Pipes, EPP Dual CAI, XDI35 HPFP, Deatschwerks LPFP, Alky Control Methonal Injection, Alky dual nozzle upgrade, Zex Nitrous, Dicunzolo Gen2 torque mounts, MSD Coils, SP542 .026, 160 T, 3bar, Catless Downpipes, custom stainless 2.5" double xpipe w/muffler deletes 4" quad tips, UPR Dual Valve Catch Can, Derale 10000 series 16 row trans cooler, 13+ PP Trans Cooler, Econoaid throttle Body Booster, Mickey Thompson 20x9 SC-5 Wheels, Continental Extreme Contact DW tires F: 245/40/20 R: 275/35/20, H&R Springs all around w/rear cut 1/2", 1" hubcentric wheel spacers m14 1.5 stud/lug conversion, Aeroforce Interceptor Gauge.
Highest Trap Speed 123.22 mph
PB 11.368 @ 122.68 NED 10/20/19
Offline SM105K
  • IG @egocheckersho
  • Forum Supporters
  • Arizona
  • -Given: 1036
  • -Received: 1198
  • Thee Forum Cowboy
  • Liked:
  • Likes Given: 13
Re: PTP Turbo Blankets
« Reply #1 on: January 31, 2020, 08:43:48 AM »
Sounds good. I am.
"M" 2013 SHO PP | AJPTurbo E30 Tune | FS HPFP | GH Intercooler w/ DIY Ice Water IC Sprayer | PPE Downpipes | Custom Magnaflow Resonator | 3rd Cat Delete | Derale Upgraded Trans Cooler | Dicunzolo Gen2 Trans Mounts| EPP Noisemaker Eliminator | MSD Coil Over Plugs | SP-542's | UPR Dual Valve Catch Can | K&N Drop In | Power Stop Slotted and Drilled Rotors with Stock PP Pads | H&R Springs  | AVS Flush Deflector | 802SHO Custom Splitter | Duraflex Chin Spoiler | Curva Concept C7's | Continental DWS06 Extreme Contact Rubber |
Offline 802SHO
  • RotM Winner
  • -Given: 2353
  • -Received: 1133
  • Boosted
  • Liked:
  • Likes Given: 0
« Reply #2 on: January 31, 2020, 09:20:37 AM »
Putting the turbo blankets on though...may be the real test lol.  Tight like a tiger
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13013
  • -Received: 4215
  • Liked:
  • Likes Given: 0
« Reply #3 on: January 31, 2020, 10:12:09 AM »
If so, then only Exxon fuel can be used.  And you can only eat Kellogg Frosted Flakes.  And wear striped underwear.  And ...
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13013
  • -Received: 4215
  • Liked:
  • Likes Given: 0
« Reply #4 on: January 31, 2020, 10:14:42 AM »
These have been successfully used on the 2.7EB Edge Sport
 - Turbo blankets
    Comp Turbos: They are not on the web site call and ask for Ernie
        http://comp-turbo.mybigcommerce.com/turbine-blankets/
What else has been developed for that engine
https://www.fordedgeforum.com/topic/24317-the-ultimate-27tt-aftermarket-parts-thread/?do=findComment&comment=185373
« Last Edit: January 31, 2020, 10:16:57 AM by SHOdded »
Offline aaron240
  • Newbie
  • cambridge ohio
  • -Given: 0
  • -Received: 5
  • Liked:
  • Likes Given: 0
« Reply #5 on: January 31, 2020, 10:52:22 AM »
Andrew as we spoke about posting this to the forums I guess I do have an account on this forum after all. Hopefully they make these for the platform! Ill check in with them periodically to show there is indeed interest. Curious as well how install will go, im sure there prob isn't allot of room to work with.
2015 non-pp SHO, 20x9 forged Saleen wheels, EPP polished hotpipes, HKS SSQV BOV, Green drop in filter, PTU Flex undertray, OrtizCustomPods dual gauge pod, aeroforce dual gauges, pp steering wheel, Memphis Audio amp and sub, interceptor black grills, chrome trim delete.
Offline 802SHO
  • RotM Winner
  • -Given: 2353
  • -Received: 1133
  • Boosted
  • Liked:
  • Likes Given: 0
« Reply #6 on: January 31, 2020, 11:22:01 AM »
 :liar:
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13013
  • -Received: 4215
  • Liked:
  • Likes Given: 0
« Reply #7 on: January 31, 2020, 11:34:14 AM »
Sayeth you! :P
Offline bpd1151
  • Forum Supporters
  • SHOcago S/W 'Burbs
  • -Given: 2485
  • -Received: 2591
  • SHOGAZM
  • Liked:
  • Likes Given: 0
« Reply #8 on: January 31, 2020, 02:14:23 PM »
** subscribed **
World's Highest AWHP SHO (Aug. 2014 - June 2016) & World's Fastest Ecoboost SHO (Nov. 2015 to July 2019) Details Here: http://www.dragtimes.com/Ford-Taurus-Timeslip-27985.html
Offline Jordan
  • Columbia, Mo
  • -Given: 224
  • -Received: 643
  • I'm the captain of this SHIP
  • Liked:
  • Likes Given: 1
« Reply #9 on: January 31, 2020, 03:39:43 PM »
Put me down
Offline FearlessAZ
  • Just Another Dirty Desert MKS
  • Sr. Member
  • Phoenix
  • -Given: 591
  • -Received: 145
  • Liked:
  • Likes Given: 1
« Reply #10 on: February 01, 2020, 07:53:08 AM »
Would love to see how much if affects our platform and cost. I am interested but don't know if I would bite until knowing that info.
2015 MKS Ecoboost. All the factory goodies.
Offline 802SHO
  • RotM Winner
  • -Given: 2353
  • -Received: 1133
  • Boosted
  • Liked:
  • Likes Given: 0
« Reply #11 on: February 01, 2020, 01:15:57 PM »
Well they already make these things, what's a slight different in measurements?  They could make a dozen sets and they would sell.  If its not all that effective, than no harm no foul on their end.  So we should see something come out of this and then we'll know for sure.
Offline NITSOOB
  • Jr. Member
  • SoCal
  • -Given: 22
  • -Received: 19
  • Liked:
  • Likes Given: 0
« Reply #12 on: February 01, 2020, 09:25:52 PM »
I believe they reduce longevity of the turbos, our GT15s are so sensitive already..
« Last Edit: February 01, 2020, 09:39:30 PM by NITSOOB »
2013 PP SHO - 3.5" DPs, 3.5" Exhaust, 3" Coldside
Pending: 5-Blade billet wheel, AJP Tune
1/8: 8.4@86
Offline aaron240
  • Newbie
  • cambridge ohio
  • -Given: 0
  • -Received: 5
  • Liked:
  • Likes Given: 0
« Reply #13 on: February 12, 2020, 11:27:38 AM »
All,
I spoke with Manny from PTP turbo blankets regarding the turboblankets being made for our platform. He said the design team is working on it and they will be making them if there is enough interest. He said we would do a group buy at first so the more people the more affordable the blankets will be. The 3.5 ecoboost ford raptor turbo blankets are $250 for the set as a reference for what to expect price wise. He also said if anyone has a spare set of turbos they could use to mock up the blankets with that would drastically reduce the price as well. I am looking for a list of those that would be interested in a set of turboblankets for their 3.5 transverse ecoboost, SHO, MKS, Flex Explorer sport etc. The amount of interest we show determines how soon they make them and the price they will be. Price would range from $275-$400 max based upon the amount of people willing to buy.
If you want to be on the list please email me at aaronschwartz9@gmail.com or txt 7405625792 so i can update PTP with the amount of those interested.
There are several substantial benefits of using a turbo blanket.
Here are just a few:
1. A turbo blanket protects components within your engine bay. The turbo blanket isolates the heat produced by your turbocharger, and prevents that heat from damaging, or even igniting, components surrounding the turbocharger within your engine compartment, such as plastic and rubber hoses and electrical wiring, as well as painted surfaces, such as the engine bay and the surface of the hood. Also, it prevents areas of localized high temperature from damaging the engine itself. For example, a common cause of head gasket failure in turbocharged vehicles is localized heating of a portion of the engine. The heat differential between the portion of the engine near the turbocharger and the rest of the engine can cause warping of the head, and thus, head gasket failure. This has been a known cause of head gasket failure in both OEM and aftermarket turbocharged vehicles.
2. A turbo blanket improves the performance of your turbocharger by keeping "the hot side hot". In keeping the exhaust gases within the turbocharger hot, turbocharger efficiency is improved. As you may know, the hotter a gas is, the more expansive it is. Within a contained system of a specified size, the more expansive a gas is, the greater the pressure derived and thus, the greater the flow of gas to escape the containment. With this increased pressure and flow rate for a given engine RPM, the acceleration of the turbocharger's impeller is increased as compared to the same turbocharger with the engine at the same RPM but with cooler exhaust gases. This equates to faster spool up of the turbocharger, as well as greater attainable levels of boost. What a driver will experience with a turbo blanket is greater turbocharger responsiveness. The faster spool up of the turbocharger means less turbo lag and a more linear power curve.
3. A turbo blanket improves the performance of your turbocharger by keeping "the cool side cool." As you may know, it is very important to keep engine intake air cool. This is why intercoolers are often utilized with turbochargers. Similar to above, the cooler a gas is (such as intake air), the more dense it is. The more dense the intake air, the more oxygen it contains per unit volume. The more oxygen reaches the engine, the more power can be obtained. In keeping the heat of the exhaust gases contained within the hot side of the turbocharger and away from the cool side of the turbocharger and the intake path, more oxygen per unit volume reaches the engine, and thus, more power.
Below is the email I sent to PTP.
Hello PTP,
I am reaching out regarding turbo blankets for the 2015 Ford Taurus SHO I have. This application would be on the transverse mounted twin turbo 3.5 ecoboost engine. The two (2) turbos are listed as Garrett Turbos and the part number that’s referenced is Garret GT1549L. I found these stock photos showing the size and overall profile of the turbos, they are fairly small. Myself and many others on the online forums are interested in having this product available for our platform.
The platform includes:
•   2010-2019 Ford Taurus SHO
•   Ford Flex
•   Lincoln MKS and MKT
•   Ford Explorer Sport
All models I have listed have the transverse ecoboost 3.5 v6 and utilize these Garret turbos so they will fit a broad range of vehicles.
NOTE: The Garret turbo on the 3.5 ecoboost is not the same as the ford f150 3.5 ecoboost as those utilize Borg Warner turbos.
Please feel free to reach out to this email address with progress and updates on the turbo blanket design for this platform.
Thanks
