April 01, 2020, 09:51:35 AM
Author Topic: Friction modifier in rear end  (Read 1635 times)
Offline Mksmark
  • Newbie
  • -Given: 1
  • -Received: 4
« on: January 24, 2020, 02:06:43 PM »
Does the RDU need this with the 2 quarts of 80-90w? Can`t seem to find any info on this.
Online SHOdded
  • Administrator
  • : Beltsville, MD
  • -Given: 12703
  • -Received: 4160
Re: Friction modifier in rear end
« Reply #1 on: January 25, 2020, 12:39:49 AM »
No.  The clutch pack is sealed, and only the gears are serviced with fluid.  Use a quality fluid like Amsoil Severe Gear or Redline Lightweight Shockproof.
Offline Mksmark
  • Newbie
  • -Given: 1
  • -Received: 4
« Reply #2 on: March 25, 2020, 11:29:51 AM »
Well I finally got my ass under the car to find out that the RDU is puking out gear lube from the top breather. Looks like a nightmare to remove the rear cover or the refill plug. To me it looks like I need to remove the entire exhaust from the cats back as its all welded up. The clutch pack looks fine from the outside but wow are those half shafts and drive shafts dinky or what? I just changed out my Mustang GT`s half shafts with Ford performance shafts and they look like twice the size of these. I have no noise or loss of power right now but it needs attention. What do you guys think, Toast or clean it up and refill?
Online SHOdded
  • Administrator
  • : Beltsville, MD
  • -Given: 12703
  • -Received: 4160
« Reply #3 on: March 25, 2020, 11:33:55 AM »
clean up and refill.  check fluid you drain out.  If the shiny bits are all fine-sized, that is just breakin stuff, nothing to worry about.  IF you have nuggets or chunks, THAT would be something to worry about.  In the absence of any untoward sound, best practice is to drain/fill at short intervals until the fluid comes out clean.
You did not state the MY, but I believe it is around 34 oz capacity.
Offline Macgyver
  • : Reading, Pa.......
  • -Given: 81
  • -Received: 262
« Reply #4 on: March 25, 2020, 01:35:21 PM »
Did I get the wrong Fluid ? Redline's website and other posts said this was a good alternative to Amsoil $$$.
Obviously I got PTU and RDU in the pic.
Online SHOdded
  • Administrator
  • : Beltsville, MD
  • -Given: 12703
  • -Received: 4160
« Reply #5 on: March 25, 2020, 03:10:49 PM »
Nope works fine.  But if you exercise the RDU, LWSP is the better choice.  The SAE weighted oil does not have the detergency (among other things) to keep the gear surfaces clean.  Nor the moly to help prevent wear (though moly is not often used in gear oils anyway).  Not sure on the extreme pressure (EP additive) quality comparison tho.
Offline Macgyver
  • -Given: 81
  • -Received: 262
« Reply #6 on: March 25, 2020, 04:29:45 PM »
Gotcha. PTU has been done twice so far. RDU has not. 47k. I will be doing them again next spring regardless of miles so "Cheaper" flushing oil is better to me.
Maybe next year a slightly better grade.
Offline Mksmark
  • Newbie
  • -Given: 1
  • -Received: 4
« Reply #7 on: March 25, 2020, 06:05:19 PM »
Oh its a 2012 MKS with 101k. Do you think the exhaust should be dropped for this or work around it. Looks like there is another exhaust hanger welded right where the fill plug is too just to add to the fun. I bought the Motorcraft SAE 80-90 oil as I like to keep it all Ford. I have herd that there are compounds in these oils that work with the seals and barrings and are Ford specific. I bought the car with 69k and no history on fluid changes.
Online SHOdded
  • Administrator
  • : Beltsville, MD
  • -Given: 12703
  • -Received: 4160
« Reply #8 on: March 25, 2020, 06:13:33 PM »
Not sure on the MKS.  Someone who has done the work will have to speak to it ...  Probably has no drain plug, so should not have to drop the exhaust.  I think I saw a video on YT for an MKS, but I could be wrong.
Offline nickstewartroc
  • Sr. Member
  • : Orlando, Florida
  • -Given: 6
  • -Received: 83
« Reply #9 on: March 25, 2020, 06:20:21 PM »
As far as the half shafts being small, keep in mind with the torque coupler, it will only send out about 150ft/lbs to the rear
Current:
* Featured Topics
* Recent Topics
by bpd1151 | Today at 09:30:57 AM
Please don't do this, you're jumping into a thread specifica...
Re: Buying Explorer Sport - mod help
by ZSHO | Today at 07:32:12 AM
Here are the years for comparison! Best of luck. Z https://m.carcompla...
by Dannymack | March 31, 2020, 12:57:03 PM
Pretty happy with how aggressive this thing looks so far. Especially c...
Re: New Bro
by SHOstopper | March 30, 2020, 01:55:38 PM
So my hombre is a wizard and this is the finished product. I couldn�...
Re: leak in rear windshield ?
by ZSHO | March 30, 2020, 01:05:45 PM
Fingers crossed for ya! Z...
Re: F150 Boost pressure feels limited
by Defhd10 | March 30, 2020, 10:46:51 AM
The Dealership did it.  It most likely corrupted the ECU with the...
by StealBlueSho | March 29, 2020, 04:45:29 PM
https://uploads.tapatalk-cdn.com/20200329/667e0cfc909d60d4096ca5aa46f0...
Re: 2013 Ford Edge SEL 2.0 EB Transmission Relearn Process:
by SHOdded | March 29, 2020, 03:55:50 PM
Not many Edge owners on here, not active anyway.Forscan Lite has a TCM...
New recommended spark plug
by bamsho | March 29, 2020, 03:01:20 PM
Well since FMC discontinued the SP542 plugs,  I thought the SP578...
Re: Ethanol analyzer
by WinPlaceSHO | March 29, 2020, 01:44:32 PM
Ok, my "Google-Fu" wasn't working yesterday, but I fina...
Re: SCT Friday Flash Sale, Today only 3-27-2020
by tmcphail | March 29, 2020, 10:45:55 AM
Sale has been extended to the 31st !https://mailchi.mp/unleashedtuning...
Re: NEED HELP: Changing PTU oil on Performance Package PTU
by SuperPete | March 29, 2020, 07:17:10 AM
Yep Yep......
Re: Epp hot pipes air intake help
by ZSHO | March 28, 2020, 06:30:50 PM
Yup. The original Gen1intake indeed. Z https://www.ecoboostperformance...
Re: SuperPete SHO Build record
by Macgyver | March 28, 2020, 02:04:15 PM
They have a MAF cleaner. Not sure how brake cleaner does. Although I a...
Re: BBK 3.5L/3.7L V6 70MM THROTTLE BODY for 10-19 SHO/FLEX/MKS
by Jordan | March 28, 2020, 05:21:26 AM
I've never heard of anybody having issues on the stock throttle b...
Back to top
