I'm a big fan of CG products and when it comes to the "buffer", I use the cheap yet pretty good digital rotary polisher from Harbor Freight. This one to be exact
http://www.harborfreight.com/power-tools/polishers/7-inch-electronic-polisher-66615.htmlNow I'm not saying its an awesome polisher, but it does go round and round and it will speed up and slow down when I want it to and it doesn't screw that up too much, so it works. At very low RPM settings when load is applied, it wants to speed up / slow down / speed up / slow down, etc almost like thats' what it is supposed to do, but clearly no polisher should do that. It only happens at very low speeds and I'm not usually running that low, so I can live with this fault. Besides, if I'm going that slow, I might as well do it by hand!
Now then, what makes this a solid polishing setup for me is the Chemical Guys backing plate and the Hex Logic pads I use. That's the magic ticket, along with the right products.
I used to be deep into Meg's Ultimate products, and I still keep them around for cars in the family that aren't a big priority. But I've moved on when it comes to my personal rides.
For me, detailing my '13 TBM Flex is all about getting that silica glass flake to "pop", and pop hard. Example:
And before I bought my '13, I had a 2010 which I also lavished with CG products.
Zaino clay bar (CG or others would be fine too, I just happen to have a lot of this stuff and its good)
CG soaps (Citrus wash and gloss lately)
CG Optical grade compound polishes (32, 34, 36, and 38), used as needed to pull out imperfections and get things prepped. I use Hex Logic orange or white pads with them.
The magic trick, Blacklight. I use this with a white pad if I need to cleanse the surface, or a black pad if it all looks pretty good overall. After a coat by machine I buff it off, and then coat by hand.
Jet Seal 109. Man I love this stuff. Two coats by hand, following cure time recommendations in between.
If I'm feeling it, I'll top it with CG 5050 Concours wax. I feel its just for show, and honestly the 109 does a lot on its own so this is just if I feel like rubbing down my car with wax just for the sake of doing it. Pops flake even more I think though.
Best part, the 109 is awesome on the windshield and other places you don't want to get wax (like our dark plastic trims, which are ruined with regular waxes.)
For the interior, I love Inner Clean. Also gotta have the scents, right? And for vinyl exterior I like G6, but I also use VRP sometimes. I go through gallons of V7 detail spray / sealant simply because it does everything.
With the right pads, backing plate, and chemicals to use, it is hard to screw up even with a rotary.
