B1086- Air Distribution Damper Motor - Panel/floor/defrost not working
Started by Gjkrisa, January 20, 2020, 07:38:07 PM
That should be the correct part number AFAIK. Z   :)
Motorcraft - Part # YH1779 (19E616)
Usage: Air Inlet Mode Door, 02/06/2012 - 03/01/2019, Taurus, Dual Zone Auto Temp Control A/C
Section: Heater/Air Cond.External Components
https://parts.ford.com/shop/en/us/climate-control/ac-repair-parts/motor-assy-7836065-1
MOTORCRAFT YH1779
FORD- AA5Z19E616C- Heater Blend Door Actuator
https://www.rockauto.com/en/partsearch/?partnum=AA5Z19E616C
Gjkrisa
#16
Well don't think that was the issue. Here is the code I'm getting I should have thought to check fuses first but thought more would go out by one fuse but I'm sure I'm wrong so I'm going thru the book. Unless you guys know anything before me.
I have alot more fuses under the driver side but can't find description of those just under the hood and passenger side fuses. I guess the driver is passenger side since there are non in that side.
Wish they gave me a fuse pulling I haven't been able to grab any with my cold fingers.
Sent from my Pixel 4 XL using Tapatalk
B1086:07  Air Distribution Damper Motor: Mechanical Failure  INSPECT for binding/damaged linkage or door. REPAIR as necessary. If no condition is found, INSTALL a new defrost/panel/floor mode door actuator. REFER to Section 412-01 . CLEAR the DTCs. REPEAT the self-test. TEST the system for normal operation.
B1086:11  Air Distribution Damper Motor: Circuit Short to Ground  GO to Pinpoint Test J .
B1086:12  Air Distribution Damper Motor: Circuit Short to Battery  GO to Pinpoint Test J .
B1086:13  Air Distribution Damper Motor: Circuit Open  GO to Pinpoint Test J .
Pinpoint Test J
The HVAC module runs off a fuse in the BJB, and controls power/operation of the blend door actuators.  Very likely the problem is in the connector/wiring, or in the HVAC module itself if replacing the blend door does not work.
Gjkrisa
Quote from: SHOdded on March 07, 2020, 03:03:12 AM
Pinpoint Test J
So if the blend door actuator works then maybe there is something broken in the blend door? Or maybe that is still frozen shut?  Or since I still get open circuit then that means the HVAC module maybe?
For the last week when driving the climate would trunk off and the error said something about timeout but no actual code. So I'm leaning towards replacing the HVAC module except for the motor works when  I run the test.
Gjkrisa
This is what it tells me when I unplug the motor
Have you replaced the mode door actuator yet?
Gjkrisa
Quote from: SHOdded on March 07, 2020, 06:53:15 PM
I replaced this AA5Z19E616C what forscan calls HVAC damper position motor
There is sometimes a re-calibration procedure which need to be initialized Prior IIRC!
Both Blend door actuators on the (Passenger side) call for the same part numbers.. The one on the (Driver's side) calls for a different part number AFAIK. Z
NOTE: The purpose of the module actuator position calibration is to allow the HVAC module to reinitialize and calibrate the actuator stop points. To carry out calibration, carry out the following steps. Remove Smart Junction Box (SJB) fuse 15 for at least one minute. NOTE: When the ignition switch is switched to the ON position, the HVAC module will initialize and calibrate the actuators. Calibration of the actuators will take approximately 30 seconds. Reinstall SJB (Smart Junction Box) fuse 15. Turn the ignition switch to the ON position and wait 30 seconds before verifying correct temperature blend door operation
Gjkrisa
#23
Quote from: ZSHO on March 08, 2020, 12:01:38 PM
What fuse should I be looking for because non of these 15 slots look right except for 46 is climate control module
But being the fuse is so hard to get out I'm going to try using forscan to just reinitialize the module.
FSM recalibration:
Reinstall SJB fuse 15. Turn the ignition switch to the ON position and wait 30 seconds before verifying correct mode door operation.
Slot 46 which has 10amp Fuse. (Climate control module).  Z
Gjkrisa
Quote from: ZSHO on March 08, 2020, 03:21:11 PM
Little bit different :s
Or no you did take that under the driver ?
They look about the same IMO! That's right under the (Drivers side) dash. Fingers crossed for ya. Z
Gjkrisa
Quote from: ZSHO on March 08, 2020, 07:53:55 PM
Finally got the fuse pulled using wire strippers
Gjkrisa
#29
Nope still didn't work I removed both 15 and 46 had to use a small flat head to get to 15
Used a timer for the 1 minutes and the 30 seconds when I turned it on still didn't sound like it was even trying to calibrate
