September 26, 2020, 03:54:18 AM
Author Topic:  Wrapping intake pipe, numbers are out<<<  (Read 19048 times)
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13013
  • -Received: 4215
  • Liked:
  • Likes Given: 0
Re: Wrapping intake pipe, numbers are out<<<
« Reply #15 on: February 11, 2020, 09:54:08 AM »
Until it catches on fire?  >:D
yeah, IDK it is ridiculous they don't support it.  charge a decent amount of money if you must, but give the customer what they want ...
Offline SuperPete
  • Full Member
  • Pennsylvania
  • -Given: 12
  • -Received: 105
  • SHO Kind of guy
  • Liked:
  • Likes Given: 0
« Reply #16 on: February 11, 2020, 04:14:44 PM »
Not what they want, give customer what your advertise, LOL
You sell cold air intake that has "gasket" to insulate from engine bay, then put one that works as advertised, if they feel like it don't need to touch hood, why bother with gasket at all?
Right?
2014 SHO, GearHead TUNNED /Powered by Matt Robinson
PPE Downpipes, GearHead Intercooler, AirAid Intake
XDI-35 HPFP @ E40,   MSD Coilpacks
MUSTANG DYNO: 426/446
Continental Extreme Contact 06 & Powerstop Z23 all 4 corners
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13013
  • -Received: 4215
  • Liked:
  • Likes Given: 0
« Reply #17 on: February 11, 2020, 04:23:22 PM »
Exactly.  I guess we have to fix what they broke.  LOL
Offline SuperPete
  • Full Member
  • Pennsylvania
  • -Given: 12
  • -Received: 105
  • SHO Kind of guy
  • Liked:
  • Likes Given: 0
« Reply #18 on: February 12, 2020, 09:35:27 PM »
First AirAid sent me same gasket I already had.
I replied back telling them this is now what I asked for and they told me that this is only gasket they have and have nothing else to offer.
Then I replied with this link as a reference: https://www.ecoboostperformanceforum.com/index.php/topic,3492.msg54567.html#msg54567
Reply attached
Hallelujah
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13013
  • -Received: 4215
  • Liked:
  • Likes Given: 0
« Reply #19 on: February 13, 2020, 01:16:02 AM »
Glad it worked, now let's see if it actually ships.  LOL.
Offline ZSHO
  • Forum Supporter
  • Forum Supporters
  • New York SHO
  • -Given: 1939
  • -Received: 4077
  • Liked:
  • Likes Given: 0
« Reply #20 on: February 13, 2020, 09:08:58 AM »
I also had Airaid send me an upgraded Taller seal (strip) many years ago and after much trial & error needed to bend the seal (outwards) due to the seal touching the inside hood liner while ultimately leaving an indentation..
I found using a heat gun on the seal to be ideal in order for the hood to close and seal properly.. Some food for thought. Z
« Last Edit: February 14, 2020, 07:04:17 AM by ZSHO »
Offline SuperPete
  • Full Member
  • Pennsylvania
  • -Given: 12
  • -Received: 105
  • SHO Kind of guy
  • Liked:
  • Likes Given: 0
« Reply #21 on: February 13, 2020, 07:08:14 PM »
You guys ready for this?
WOW, AirAid, top gasket is what they sent me today, bottom is old original
For real?
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13013
  • -Received: 4215
  • Liked:
  • Likes Given: 0
« Reply #22 on: February 14, 2020, 04:16:01 AM »
What a joke!
Offline Davidsiebert2
  • Jr. Member
  • -Given: 1
  • -Received: 5
  • Liked:
  • Likes Given: 0
Re: Wrapping intake pipe, numbers are out&lt;&lt;&lt;
« Reply #23 on: February 25, 2020, 08:15:54 AM »
@SuperPete
Thatís because the wrap you used doesnít do much for a radiant barrier. Use a reflective heat radiant barrier tape and you will see better results. I dropped my max iat2 idle temp after extended driving to 130ish degrees. Before the radiant tape on my hot pipes and cold air pipe my extended drive then idle temps would exceed 140 deg f.
That exhaust wrap is going to take whatever heat soaks into that pipe and keep it in that pipe.
Offline HD-Rugby
  • Jr. Member
  • SE PA
  • -Given: 59
  • -Received: 5
  • Liked:
  • Likes Given: 2
« Reply #24 on: April 24, 2020, 09:08:19 PM »
Does the hood close properly ? Here is a PIC of the Taller Strip for comparison. Z
Iíd like to know more about your oil cap...
Offline ZSHO
  • Forum Supporter
  • Forum Supporters
  • New York SHO
  • -Given: 1939
  • -Received: 4077
  • Liked:
  • Likes Given: 0
« Reply #25 on: April 25, 2020, 07:28:16 AM »
Its a first gen RX CSS! Nice quality piece for sure. Z   :)
« Last Edit: April 25, 2020, 07:31:05 AM by ZSHO »
Offline avidmotion
  • Sr. Member
  • -Given: 5
  • -Received: 87
  • Liked:
  • Likes Given: 0
« Reply #26 on: April 27, 2020, 03:22:36 PM »
I have the RXP OIL separator system also, great quality, works well....hidden in wheel well drivers side. Your motor sure is shiney clean!
Sp542@.028, windstorm CAI, MSD coils, AO GH TUNE, GH intercooler, All Amsoil, General Gmax-rs summer tires, +PP, PP PADS,EDC rotors, Colinite 476s wax, Resonator | 3rd Cat Delete with custom X pipe, Dicunzolo Gen2 Trans Mounts|, 3 bar, stock thermostat,  TRACY LEWIS DESIGNED Team RXP, the Original oil separator.
* Recent Topics
Re: BamSHO 12.14 MIR Extra Preppy!!
by bpd1151 | September 25, 2020, 10:27:57 PM
Sucky sucky, licky licky. Brian you filthy, slutty hoe.Sent from my SM...
Re: SHO vs Hellcat Redeye
by bamsho | September 25, 2020, 09:32:46 PM
What rims and tires are you running on the fronts?  You gapped hi...
Re: Need inexpensive tires for my 2013 SHO
by avidmotion | September 25, 2020, 08:19:45 PM
https://simpletire.com/brands/general-tires/g-max-rs#v=1&tireSize=...
by GotGrip? | September 25, 2020, 04:24:56 PM
So I was watching this ocean show with my daughter on disney+ and it w...
Re: Whiteline 24mm Adjustable Rear Sway Bar for 2010-2019 Taurus SHO/MKS/Flex/MKT
by SHO_NVS | September 25, 2020, 02:32:21 AM
I'm in. PM sent...
Re: Water in passenger floor
by SHO_NVS | September 25, 2020, 02:28:51 AM
Oh man, glad you found it.  Hopefully that fixes it.  I live...
Re: Carbon hood install
by SHO_NVS | September 25, 2020, 02:23:04 AM
That looks nice! Good job!...
Re: Wheel pulls bad one way then snaps back
by SHO_NVS | September 25, 2020, 02:18:05 AM
Glad you found that loose bolt, crazy.  How do you like the down ...
Re: And the award for most frequently broken car goes to...
by Macgyver | September 24, 2020, 10:28:06 PM
Oh Boys. Lets hope she holds together !!!...
Re: Daily driver MKT
by TopherSho | September 24, 2020, 08:07:20 PM
:zumbujump: :zumbujump: :zumbujump: :zumbujump: :) :) :)Curious of op...
