3-12-2020 Update
Did some maintenance to the car, all fluids changes, PTU is a royal pain to get to with the PPE Catted downpipes, so I have to drill drain hole on the bottom later and update you on that if I can get to drilling without removing the downpipe anyway, thats for later.
Still have a issue with boost leak, somewhere small leak, Matt pointing me to the waistgate closed 100% and still not holding boost, I start up with 18psi and by the end of the gear with fully closed WG drop to 12-13.
I already removed "NoiseMaker" pipe and replaced with aftermarket, checked blow-off valves membrane, all good there, check all connections, kind of did everything I can think of, did pressure test and still dropping pressure, so this Saturday weather is nice, I am getting to the bottom of that, will find that boost leak and fix it, bottom line
OR if my turbos are "tires" new blowers will be on the way, anyway I will report in few days with updates.
Thank you all
