August 05, 2021, 11:06:06 AM
Author Topic:  CA smog & down pipes  (Read 2651 times)
Offline Chaplain
  • Newbie
  • -Given: 6
  • -Received: 1
  • Liked:
  • Likes Given: 0
« on: December 23, 2019, 11:59:34 PM »
Does anyone make down pipes that will pass California smog?
Offline bpd1151
  • Forum Supporters
  • SHOcago S/W 'Burbs
  • -Given: 2562
  • -Received: 2661
  • SHOGAZM
  • Liked:
  • Likes Given: 0
Re: CA smog & down pipes
« Reply #1 on: December 24, 2019, 08:01:36 AM »
I believe PPE Engineering in AZ. has previously been reported to pass.
Hopefully others will chime in, and consider contacting them directly to inquire.
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13054
  • -Received: 4248
  • Liked:
  • Likes Given: 25
« Reply #2 on: December 24, 2019, 08:08:37 AM »
No, only OEM qualifies to pass CA smog, or CARB labeled downpipes.  PPE does not have CARB certification.  Not sure that any performance downpipe will get CARB certification ...
To clarify, PPE will pass the tailpipe tests/OBD tests, just not the visual inspection.
You can keep the OEM and swap it out when it comes time.  A lot of folks do that.
Offline ZSHO
  • Forum Supporter
  • Forum Supporters
  • New York SHO
  • -Given: 1945
  • -Received: 4088
  • Liked:
  • Likes Given: 0
« Reply #3 on: December 24, 2019, 09:48:34 AM »
I'm not quite certain if CALI will even pass a Federal emissions vehicle,so go figure. Z
« Last Edit: December 24, 2019, 09:59:14 AM by ZSHO »
Offline Chaplain
  • Newbie
  • -Given: 6
  • -Received: 1
  • Liked:
  • Likes Given: 0
« Reply #4 on: December 24, 2019, 03:26:27 PM »
Thanks for the response.
How intense is the visual?  Guess I've only ever seen a smog guy open the hood and if nothing stood out moved onto the next item on his check list.  Unless you go looking for them, down pipes don't really stick out and I don't see a smog guy getting under the car to check.  Am I wrong on this?
With that said I have kept my oem exhaust from the flange back to reinstall just incase my modified Magnaflow system doesn't pass.  Doing a R/R on that is much easier than R/R a pair of down pipes.
For those of you who have done a catted down pipe swap from oem.  Is there much gains to be made to make it worth the work?
« Last Edit: December 24, 2019, 03:34:03 PM by Chaplain »
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13054
  • -Received: 4248
  • Liked:
  • Likes Given: 25
« Reply #5 on: December 24, 2019, 03:43:44 PM »
All they do is look for a CARB certification sticker on the ... catalyst, I believe.  Otherwise they would not possibly know OEM from aftermarket, except that aftermarket is usually MUCH prettier :D
Offline Dxlnt1
  • Los Angeles, CA
  • -Given: 123
  • -Received: 137
  • SHO-NUFF
  • Liked:
  • Likes Given: 0
« Reply #6 on: December 24, 2019, 05:34:43 PM »
I failed smog because I had to go to a "STAR" certified shop. Who sometimes are more stringent with everything.
You only have 2 options:
1. Swap your exhaust every couple years for smog inspection
2. Find a shop that looks the other way.
Neither choice is cheap. I chose option 2. As I REFUSE to continually change exhaust for Cali and some of its STUPID crap it keeps handing down that a whole lot of people keep voting for!
2011 SHO, 3 Bar AJP Turbo-Tune, ACES IV, 170 T-stat, PPE Catted DP's, Alpine Sound system, Touch screen HVAC controls, full window tint
Offline Chaplain
  • Newbie
  • -Given: 6
  • -Received: 1
  • Liked:
  • Likes Given: 0
« Reply #7 on: December 24, 2019, 05:46:39 PM »
This is my first emission modified CA plated vehicle.  All my past vehicles I kept plated out of Colorado or Arizona, but I got sick of being pulled over for out of state plates (and my beautiful bride was over it).
Offline Dxlnt1
  • Los Angeles, CA
  • -Given: 123
  • -Received: 137
  • SHO-NUFF
  • Liked:
  • Likes Given: 0
« Reply #8 on: December 25, 2019, 05:04:57 PM »
Try finding muffler shop. They often have someone on tap that help with Cali smog. And as stated, the fail is the visual. The emissions themselves are good and within spec.
Remember if your car has a tune on it, to put car back to stock tune and drive it 10-20 miles before inspection
Offline SM105K
  • IG @egocheckersho
  • Forum Supporters
  • Arizona
  • -Given: 1049
  • -Received: 1221
  • Thee Forum Cowboy
  • Liked:
  • Likes Given: 22
« Reply #9 on: December 30, 2019, 11:05:36 AM »
The PPE catted down pipes will pass the emissions test.  I highly doubt the tech doing the test will get under the car, much less pull the skid plate off to look.
Also the PPE catted down pipes are worth every penny on the performance side as well.  They are a direct bolt in.  Keep your stock DP's and go from there.
There are various reasons why I left Dumbeffistan, this being one of them.
"M" 2013 SHO PP | AJPTurbo E30 Tune | FS HPFP | Stock IC with Ice Water DIY Sprayer | PPE Downpipes | Custom Magnaflow Resonator | 3rd Cat Delete | Derale Upgraded Trans Cooler | Dicunzolo Gen2 Trans Mounts| EPP Noisemaker Eliminator | MSD Coil Over Plugs | SP-542's | UPR Dual Valve Catch Can | K&N Drop In | Power Stop Slotted and Drilled Rotors with Stock PP Pads | H&R Springs  | AVS Flush Deflector | 802SHO Custom Splitter | Duraflex Chin Spoiler | Curva Concept C7's | Continental DWS06 Extreme Contact Rubber |
* Recent Topics
Re: Random Pull/Torque Steer after new moog lower control arms.
by mystery101 | Today at 10:38:19 AM
Moogs were the only option for me as the OEM's were backordered t...
Re: Any advice on how to improve 1/4 mile times?
by Blackhawk | August 04, 2021, 11:46:49 PM
This car should be running at least high 11s with all those mods. ...
Re: Terrain Management System Fault - wrench light
by TopherSho | August 03, 2021, 05:45:56 PM
Good notes to keep under the hat,  thanks for the share and updat...
2010 Taurus SHO, PCM issues
by withku | August 03, 2021, 01:41:48 PM
Hey all, my 2010 has been acting up lately. A while ago, my a/c stoppe...
Re: PTU 2017 3.5 EcoBoost Explorer 20 minute Fluid change all from underneath car
by SPDboat driver | August 02, 2021, 06:28:36 PM
Good video. You think you may lose some fluid through the vent if it h...
ecoboost_xsport Consolidated Build/Maintenance Thread
by Ecoboost_xsport | July 30, 2021, 08:24:58 PM
Even though I haven't been posting as frequently lately (YouTube ...
Re: 15 Interceptor Sedan Ecoboost with GHT Tune - Engine Coolant Overtemp
by SHOdded | July 30, 2021, 02:58:41 PM
on the 2.7, ford says to replace the ECT sensor and/or the knock senso...
Boost / Vacuum Source
by Ecoboost_xsport | July 29, 2021, 12:36:21 PM
Those of you wondering where a decent place to tap into a boost/vacuum...
Re: New from Minnesota...
by PDSHO | July 27, 2021, 04:15:43 PM
Re: Ol' Guy in New England........
by PDSHO | July 27, 2021, 04:13:04 PM
