Been MIA for a while, but still messing around with the MKS. Here's what I have been up to.
1. New front strut Mounts
2. New front lower control arms
3. New PP PTU
4. Swapped plugs to 578's at .028
5. New front right axle since boot was leaking and was out for PTU
6. Starting transmission fluid swap
7. Some aesthetic work on the rear (light tint on reverse and brake and black strip across)
8. Starting a new wheel set. They are from a Maserati Ghibli. Rears are basically bolt on other than hun centric rings. Fronts are the same, but looks wise need to be pushed out a little so that is next. Setup will be staggered since I like that look. They will have some nice sticky rubber to compensate for the 245 fronts. Rears will be 275 on a 10.5 wide rim.
