April 05, 2020, 10:58:26 PM
Author Topic: Voxx Leggero, 20x9.5, +35 offset  (Read 11323 times)
Offline CaptainInsane-O
  • Jr. Member
  • : TX
  • -Given: 18
  • -Received: 22
  • Professional breaker of things. No, seriously!
« on: November 13, 2019, 09:43:33 AM »
Anyone running the 9.5" wide Voxx Leggero on their SHO?  I like the look and weight savings, but unfortunately(?) the 8.5 is back-ordered until January.
Thanks in Advance,
El Kapitan de Loco
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • : New York SHO
  • -Given: 1892
  • -Received: 3982
Re: Voxx Leggero, 20x9.5, +35 offset
« Reply #1 on: November 13, 2019, 01:56:37 PM »
I think Debonair had 20x9 Vossen Cvt wheels with Nitto invo 265-30 tires on his SHO IIRC! I hope this helps any.  Z
https://www.ecoboostperformanceforum.com/index.php/topic,4611.msg72210.html#msg72210
« Last Edit: November 13, 2019, 02:01:54 PM by ZSHO »
  • Jr. Member
  • : TX
  • -Given: 18
  • -Received: 22
« Reply #2 on: November 14, 2019, 03:17:36 PM »
The great and powerful wheel in the sky had other plans... the 9.5's are not available either (4 that showed in stock were ghosts) AND a screw took out my front passenger tire on the way home from work yesterday.  Limped the SHO into Discount and thankfully, the Continental's I requested on Tuesday had been delivered. I also decided to forego any thoughts of weight savings and ordered a set of black, 8.5" wide Mustang Performance replicas because they look mahhhvelous. New soles are on, and I am digging them but the Buford is still rocking stock shoes for around another week.
Yours Forever,
Das OF-2 of Whacked in da Melon
Offline lamrith
  • : PNW
  • -Given: 106
  • -Received: 385
« Reply #3 on: November 18, 2019, 12:02:47 PM »
Thanks in Advance,
El Kapitan de Loco
I am running the VOXX Lago 20*9.5 35 offset on my SHO with General G-MAX AS-05 275/40ZR20 tires, LOVE IT!  Traction for days, nice amount of poke from the fender, no rubbing.
You can fit 245's on them but it looks odd imho and not something I would think is good to run long term.  I did for a little bit since I had so much tread left on my 245's, but replaced the tires as soon as I found a good deal on the AS-05's.
You will need to get some hubcentric spacers/adapters to get a proper fit as the bore on the wheels is larger than the hub on the car.  Least that was the case for my Lago's, but worth checking.
'13 Sho PP, SCT x4, AJP 92-Octane rev6 (14psi&20spark) NGK 6510, 3Bar, K&N CAI, PPE Catted DP, Dynomax Axleback, 20*9.5 Voxx Lago.
  • Jr. Member
  • : TX
  • -Given: 18
  • -Received: 22
« Reply #4 on: November 30, 2019, 05:38:13 PM »
New shoes are here and going on... will get installed pics tomorrow, after I wash some of the grime off of the beater.
* Featured Topics
* Recent Topics
Re: H&R, Eibach, Godspeed
by SHOdded | Today at 10:29:43 PM
Since SHO springs and presumably MKS springs are different rates than ...
Re: Hello from MSP!
by WinPlaceSHO | Today at 05:38:36 PM
Oh, and something to add, that nut under the throttle body is tricky, ...
Re: F150 Boost pressure feels limited
by Defhd10 | Today at 02:25:45 PM
Curiosity got the best of me today so i pulled my o2 sensors as well a...
by StealBlueSho | Today at 10:47:23 AM
https://uploads.tapatalk-cdn.com/20200405/8322028b3e19c1b2021edef071a2...
Re: chrome exterior door trim
by Dannymack | Today at 08:51:25 AM
I want to wrap the chrome door trim on my s h o. I also want to wrap t...
MOVED: chrome exterior door trim
by SHOdded | April 04, 2020, 09:58:20 PM
This topic has been moved to Exterior.https://www.ecoboostperformancef...
Re: 6 Piston Wilwood UPDATE!!
by FiveLeeter918 | April 04, 2020, 09:24:18 PM
This setup designed for use with stock rotor sizes? Or will it require...
Re: Help with aftermarket bov epp hotpipes
by ZSHO | April 04, 2020, 04:51:38 PM
1." inch OD silicone high temp caps are ideal. I would avoid the ...
Re: Any Explorer Sport intercoolers available?
by 97novi2k | April 04, 2020, 08:22:35 AM
Really wish the Gearhead intercooler would work as I want one for my s...
Re: Deatschwerks DW300C Fuel Pump Updates for 2013+ SHOs
by StinkinLinkin13 | April 03, 2020, 09:10:53 AM
Yes. ...
Re: P0020 Code
by SHOdded | April 03, 2020, 03:25:31 AM
I think you are right!  Always something lol....
Re: THE EPIPHANY
by bpd1151 | April 03, 2020, 02:03:01 AM
Welcome aboard!The Fiesta's, as well as the Focus's, in ST f...
by SHOdded | April 02, 2020, 02:50:50 PM
Bring on the fire! ...
by sm105k | April 02, 2020, 06:58:35 AM
I just bought a pair of Catted PPE DP's from Vivid Racing for ano...
MOVED: Fords at Carlisle 2020
by ZSHO | April 02, 2020, 05:04:16 AM
This topic has been moved to Discussions about car shows and meets.htt...
Back to top
