May 26, 2020, 12:19:05 am
Author Topic: Possible blown PTU and or RDU?  (Read 5320 times)
Offline Gofspar
  • Jr. Member
  • Phoenix
  • -Given: 5
  • -Received: 22
Re: Possible blown PTU and or RDU?
« Reply #15 on: October 17, 2019, 12:39:41 am »
k, cold air made it happen in 2nd.
guess im looking at the PTU or RDU.
AJPTurbo E30 3bar rev4, SP-534 .28, MSD coils, reische 170 tstat, ARH Catless DP, resonator delete, magnaflow mufflers, airraid CAI, H&R sport springs, UPR Catchcan /w CCS, SSM "Street" RMM
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 12953
  • -Received: 4203
« Reply #16 on: October 17, 2019, 03:58:23 am »
Have you checked tire pressures?  Sometimes that sets off the AWD system, if the psi is too low.  We have had one member report such an incident.
Offline Gofspar
  • Jr. Member
  • Phoenix
  • -Given: 5
  • -Received: 22
« Reply #17 on: October 19, 2019, 09:21:42 pm »
The 2010 MKS should have the same final drive as the 2.77's in my SHO, right?
Why is the axle identifier 4A and not 1A?
https://www.lkqonline.com/2010-Ford-Taurus-Sedan-Carrier-Assembly/-hFnmnncnDDcnDD/-i~202161063
Offline Gofspar
  • Jr. Member
  • Phoenix
  • -Given: 5
  • -Received: 22
« Reply #18 on: October 23, 2019, 04:10:49 pm »
Just got back from a buds shop, first we checked the diff by spinning the wheels independently and everything checked out ok. then we put the car in drive on the lift and the rear wheels slowly spun. ok, seems normal.
Then if we put some pressure holding the rear tires from spinning and the driveshaft stops spinning, so im looking at catastrophic failure of the PTU despite it not making any weird noise other than when I broke it and for when I would try to get on the throttle heavy from a dig, kinda sounded like teeth skipping on something.
Has anyone broke the shaft that connects the ptu to the transmission?
Should I just bite the bullet on a brand new PTU or where should I be looking to get one used?
« Last Edit: October 23, 2019, 04:20:27 pm by Gofspar »
* Featured Topics
* Recent Topics
Re: Transfer case torque limit
by FoMoCoSHO | May 25, 2020, 09:44:56 pm
Who is your tuner?...
Re: MrHighCALiber's SHO Forged Engine Build
by StealBlueSho | May 25, 2020, 08:50:30 pm
Cylinder 2 had some issues. 0psi compression was the main one. Lolhttp...
Re: Does anyone here have a Taurus 2.0 EB?
by GhostlyGrenade | May 25, 2020, 04:40:16 pm
Hptuners most likely supports this. Email and ask them. If not they ca...
Re: EBPF Under New Ownership!
by 76fomoco | May 25, 2020, 12:19:53 pm
SBS thanks for picking up the torch and keeping this wealth of informa...
Re: EPP CAI
by 802SHO | May 25, 2020, 05:58:21 am
I ordered mine last week and it's sitting on the bench. I figured...
Re: Letís talk weight reduction?!
by 802SHO | May 25, 2020, 05:42:56 am
I think it's worth it for a couple reasons...first being youre fa...
by 802SHO | May 25, 2020, 05:27:29 am
Man that flywheel ssssure issss perrrtyyy Sent from my LM-G710VM using...
Re: 802SHO 2010 Build
by 802SHO | May 25, 2020, 05:19:39 am
I would be super intrigued on the 13+ manifolds and how they work out....
Re: Ford Recalls
by BlueSHO | May 24, 2020, 11:16:02 pm
FORD EXPLORER RECALL: SUSPENSION PROBLEMS IN 1.2 MILLION SUVS. Z ...
Re: MRT blues
by FoMoCoSHO | May 24, 2020, 10:17:35 pm
https://www.ecoboostperformanceforum.com/index.php?topic=9807.0Well, a...
Re: Brake Cooling Kit
by bpd1151 | May 24, 2020, 07:55:43 pm
None that I've found. Although I do employ the Titanium heat shie...
Re: Performance Oil Pan
by bpd1151 | May 24, 2020, 06:08:01 pm
Hey Everybody. Thanks so much for all of the comments and ideas. After...
by StealBlueSho | May 24, 2020, 05:44:23 pm
Just a quick clean with my favorite detailing product!https://uploads....
Re: 2013 MKS w/57k
by MKS Tom | May 24, 2020, 04:23:36 pm
You really will enjoy it.  It is a lot of car for the money. ...
Re: What size filter sock/cover for EPP gen 2 dual filter?
by StealBlueSho | May 24, 2020, 03:50:19 pm
I used Part Number: 20-1770 for my original version Gen 1 intake and f...
Back to top
