Ecoboost Performance
General Discussion
Help with codes
Help with codes
Started by Desmond1491, October 15, 2019, 03:51:18 AM
Desmond1491
Jr. Member
Ecobooster
Help with codes
I have a 2010 Lincoln MKS Ecoboost 3.5L AWD and I having a couple of codes showing up ...
P0020, P0030,P0050,P0130, P0150, P052D ... I also already changed the two O2 sensors but still getting codes for the sensors. Need some help
Forum Supporters
Re: Help with codes
October 15, 2019, 04:09:29 AM
Clear the codes and and see if they come back, if you have not already.
P0020 - check the wiring to the VCT solenoid on bank 2. May be a dirty connector or a pin pulled out of the connector, etc. Has been known to happen.
P0030 & P0050 - have you installed downpipes recently? Using any adapters? Are the new sensors Motorcraft? Any leaks in the exhaust system?
P052D - also related to the VCT solenoid. Should clear up if the P0020 clears up. If not, then replacing the solenoid is the likely solution.
Desmond1491
Jr. Member
Ecobooster
Re: Help with codes
October 15, 2019, 04:16:19 AM
To P0030 & P0050 the new sensors are motorcraft no new installation on downpipes.... p0020 what would be the best way to clean the connector ?
Forum Supporters
Re: Help with codes
October 15, 2019, 08:39:39 AM
Disconnect the battery first. Liberally spray MAF Sensor Cleaner or Electrical Parts Cleaner into the connectors on both ends, solenoid and harness. Use a stiff toothbrush to clean off the pins. Spray some more cleaner for a final cleaning. A dab of dielectric grease on both connectors and seal back up.
My guess is a loose pin in the harness, that seems the most common issue with the SHO where VCT solenoids are concerned.
Forum Supporter
Forum Supporters
Trap Speed of almost 116 mph.
Re: Help with codes
#4
October 15, 2019, 09:05:58 AM
Since you have a 2010MY inspect the wiring for any chaffing or corrosion especially on the harness connector!
I believe the VCT solenoid is located right under the Battery tray IIRC! Z
2013 Performance Package SHO| Livernois Custom Methanol Tune|3-Bar Map|Reische-170-Stat|Full Race Tial-10psi BOV in Black|PPE-Gloss Black Hot Pipes|EPP Dual Intake in Gloss Black|PPE Catted DP|Corsa Sport Cat Back Exhaust|H&R Sport-Springs|CFM Performance Billet Valve Cover Breather In Gloss Black|Llumar 20%Ceramic window Tint|MSD Ignition Coils in Black|Extreme Roof Spoiler|Redline Fluids all around|Gearhead Intercooler|
First-SHO With Direct Port Alky-VP-M1-100%-Methanol Injection|LMS-Custom-Dyno-Tuned
@ 415whp-465wtq|
Best Trap Speed of 115.54 mph|
General Discussion
Help with codes
