Ecoboost Performance
Performance
Boost a Pump to upgrade LPFP
Started by Gray Brick, September 04, 2019, 06:42:14 PM
Gray Brick
Sr. Member
Gray Brick
Has anyone experimented with the Kenne Bell Boost-a-Pump?
I have an upgraded HPFP and it seems my bottleneck is the LPFP at this point.
http://kennebell.net/accessories/boost-a-pump/
2013 Ecoboost Ford Flex
AJP Tune (ATP+2) in progress , Livernois HPFP, 3 Bar MAP, UPR Catch Can, 100% Methanol w/ braided steel lines, 3" Downpipes -->2.5" X-pipe --> 2.5" Magnaflow exhaust, 2.5" air inlets to each turbo with cone filter, Custom water to air intercooler with chiller
275/40-20 Front 315/35-20 Rear Tires
---12.419ET/112.43MPH @ 5150 lbs in the 1/4---
Forum Supporters
Re: Boost a Pump to upgrade LPFP
September 04, 2019, 07:00:22 PM
Years ago ... if you search on Ecobrick Bob's posts (he also had a Flex), you will find his opinion on this upgrade.
EcoPowerParts.com used to have a drop in LPFP upgrade, don't know if it is still offered, and if the OEM PCM can accommodate it.
Gray Brick
Sr. Member
Gray Brick
September 04, 2019, 07:23:39 PM
Would there be any reason that a boost a pump would not work for our platform?
Macgyver
Super Moderator
2020 Red ST
September 05, 2019, 02:02:50 AM
Even in my Nissan Juke. We have LPFP upgrades.
Why not the Fords of this platform.
Performance
