PolskiMeth V2
Started by polskifacet, August 14, 2019, 03:19:32 PM
polskifacet
Hey guys,
Did a small revision of my meth setup. Changed to a Snow Performance nozzle and EcoPower noisemaker pipe with 1/8th meth bung.
Also Mix is:
Splash washer fluid + 48 oz denatured alcohol (per gal)
Tip:
My push connect fittings were leaking. Replaced the nylon hoses with new ones, no more leaks.
Gray Brick
The push fittings will leak again.... switch to braided steel with -an fittings.
2013 Ecoboost Ford Flex
polskifacet
Quote from: Gray Brick on August 14, 2019, 06:46:55 PM
Were fine until i disturbed them. Snow pump has push connect fittings so no point in only switching some.
TopherSho
What elbow are you using... I'm on my 5th devil's own elbow.
Best 0-60 public road 4.35s
polskifacet
Quote from: TopherSho on August 14, 2019, 10:51:09 PM
Ones from McMaster-Carr
