May 27, 2020, 07:29:21 am
Author Topic: 2014 pp driveline in 2010 sho questions.  (Read 7566 times)
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 12953
  • -Received: 4203
Re: 2014 pp driveline in 2010 sho questions.
« Reply #15 on: September 06, 2019, 05:26:31 pm »
Offline Spyder3000gtvr4
  • Full Member
  • Suffolk county, LI ny
  • -Given: 29
  • -Received: 4
  • Ecobooster... maybe
« Reply #16 on: September 06, 2019, 06:09:07 pm »
Ok will look up what the best option is with the secondary cooler line. As far as the wiring the smaller one seems to want to go to the starter clips in nice and easily has a clip thatís snug. The  thicker one with two wires on it can make it to the starter but Iíd have to pull on the wires a bit so thinking itís the smaller one.
Kik: Spyder3000gtvr4
Got my Sho deciding to make it a DD or use it for my tube chassis build :)
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 12953
  • -Received: 4203
« Reply #17 on: September 06, 2019, 08:01:36 pm »
Sorry cant help with that one :(
  • Full Member
  • -Given: 29
  • -Received: 4
« Reply #18 on: September 17, 2019, 10:47:47 am »
So i just left the local ford dealership, Was trying to look into the parts for the second antifreeze line and the gentleman couldnít find them. So tried for about half an hour. So going to have to see if I can find the parts needed to see if itís worth adding the parts or just capping it. Not really in the mood to take off the intake to see whatís involved in swapping out the 2010 single line
Time involved researching/working on car: well over 100hours
Time driving the car: lol less then 10hours!
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 12953
  • -Received: 4203
« Reply #19 on: September 17, 2019, 02:54:51 pm »
Just cap it!  Do go thru the shoforum thread.
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • New York SHO
  • -Given: 1932
  • -Received: 4056
« Reply #20 on: September 17, 2019, 10:04:26 pm »
I wholeheartedly agree with Manu and simply put a cap on it and be done with it. Z  :)
« Last Edit: September 18, 2019, 06:37:46 am by ZSHO »
  • Full Member
  • -Given: 29
  • -Received: 4
« Reply #21 on: October 06, 2019, 05:10:11 pm »
Got the car all together. Put the key in glove box cranked nothing. Cracked second time it sputtered now all itís doing is cranking. I donít think the fuel pump is on and the security light is flashing. Any advise... remote is dead only works in glove box. Tried locking the car putting code in the door so donít know if itís a security issue or if the fuel pump needs to be reset since the battery was out for 6 months.
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 12953
  • -Received: 4203
« Reply #22 on: October 06, 2019, 05:59:30 pm »
If it were a loss of PATS security communication, it would not even crank, so that is not it.  Key fob battery or vehicle battery or both could be suspect.  Could be low or bad fuel from sitting.  Recheck and firmly seat all fuses and relays in the underhood fusebox.  Make sure the connectors at the PCM and whatever else you disconnected are good.  Can you get codes from the PCM?  I would think if it cranks, it can set codes.
  • Full Member
  • -Given: 29
  • -Received: 4
« Reply #23 on: October 06, 2019, 08:15:21 pm »
Battery is a ur old and was on the trickle charger during the engine transplant, key fob is dead but battery is a yr old and only wants to crank when itís in the key holder. Gas is 93 6 months old topped it off 10 miles prior to engine going. Iíll have to get a code reader to see if I can get anything. From what I recall if the hoods open and youíre standing at the engine bay I thought Iíd hear the hissing from the fuel system. I donít hear anything at all now and even after trying to crank the engine 6-7 times no smell at all even at the exhaust tip. I feel like the fuel pump isnít going. Thatís why I thought it had to do with the security since the red light was blinking in the car
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 12953
  • -Received: 4203
« Reply #24 on: October 07, 2019, 02:07:38 am »
According to this, one of the antennas might have failed, requiring the fob insertion into the center console slot.  Assuming the key fob battery is new.  As to why it cranks but not starts, let's see about the codes.
Quote
Normal Operation
During each vehicle start sequence, when the start/stop switch is pressed, the Remote Function Actuator (RFA) activates all 3 passive start antennas, which send out a low frequency signal. If an Intelligent Access (IA) key is within range of an passive start antenna, the low frequency signal activates the IA key. When the IA key is activated it sends a high frequency signal to the Remote Functions Receiver (RFR) module. The RFR module communicates with the RFA module. If the RFA module determines that a programmed IA key is in the vehicle, it interacts with the PCM to start the vehicle.
If the vehicle has a failure of any passive start antenna, the battery in the IA key, or the RFR module, the vehicle can experience a Passive Anti-Theft System (PATS) no-start. However, in the event of one of these failures, the IA key can be placed in the backup slot (located in the center console) to allow the vehicle to start. The backup transceiver is located next to the backup slot and activates an IA key if it is placed in the slot. The backup transceiver is hardwired to the RFA module and when it is activated, sends out a low frequency signal. If a programmed IA key is in the backup slot when the backup transceiver is activated, it activates the IA key and the identification code is sent back to the RFA module through the backup transceiver.
Once the RFA module determines that a programmed IA key is inside the vehicle and receives a request to start the engine, it turns the ignition ON and communicates with the PCM over the High Speed Controller Area Network (HS-CAN). Once the ignition mode is turned ON, both the RFA module and PCM check the parameters against what has been programmed into them. If there is a programmed IA key inside the vehicle and the parameters are correct, then the RFA module and PCM enable the starter relay and fuel injectors.
Quote
PATS disables the vehicle from starting if there is:
  • a damaged IA key.
  • a damaged IA passive start antenna (of the 3 used for starting the vehicle).
  • an unprogrammed IA key.
  • a non-encoded (non- IA ) key (a conventional PATS key or one that does not have any electronics).
damaged wiring. [/li]
[li]a damaged backup transceiver (only if the IA key is in the backup transceiver slot). [/li]
[li]a dead battery in the IA key (backup transceiver slot may be used to start the vehicle in this case). [/li]
[li]a damaged RFR module. [/li]
[li]a damaged RFA module. [/li]
[li]a damaged PCM.[/li]
[/list]
Offline tarmstrong
  • Forum Supporters
  • Jr. Member
  • -Given: 0
  • -Received: 12
« Reply #25 on: October 07, 2019, 08:32:27 am »
Any chance the fuel pump safety switch has been tripped?
2018 Maroon PP SHO
K&N Drop-in
Previous: 2015 Dark Side Metallic PP SHO
3 Bar, K&N, Tune
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • New York SHO
  • -Given: 1932
  • -Received: 4056
« Reply #26 on: October 07, 2019, 05:35:57 pm »
Do you hear a (click sound) coming from the engine bay after having it in accessory mode then ignition OFF ? Z
« Last Edit: October 07, 2019, 05:52:49 pm by ZSHO »
  • Full Member
  • -Given: 29
  • -Received: 4
« Reply #27 on: October 07, 2019, 08:35:00 pm »
Thatís what Iím trying to figure out. I looked in the manual itís very vague on how to reset it. Googled it... nothing. Tried the search on here but didnít seem to find it (probably using the search wrong)
The only other thing I could possibly think of is that I put the flywheel in the wrong spot which I highly doubt but even if I did Iíd still smell gas which I am not. Not hearing the hissing for it to prime.
As far as a clicking Iíll go check but I donít recall. A buzzing sound near the trans and the fpr is making a very faith buzzing
  • Full Member
  • -Given: 29
  • -Received: 4
« Reply #28 on: October 11, 2019, 01:00:01 pm »
Havenít had time to look at the car again will try this weekend. Will listen for clicking sound as mentioned. I saw the article about the recall for the fuel pump module not sure it that applies to my car. Was thinking of trying starter fluid to see if itís the fuel pump any suggestions on testing the pump?
* Featured Topics
* Recent Topics
Re: 802SHO 2010 Build
by 802SHO | Today at 06:17:39 am
Honestly that's not alot of $ for better flow vs our manifolds IM...
by bpd1151 | Today at 01:21:26 am
I'm hoping that that opening line is laden with sarcasm.Actually ...
Re: Updated Gallery Capabilities
by bpd1151 | Today at 01:10:42 am
I have some time off from work coming up soon. I'll have to check...
Re: Transfer case torque limit
by 10sleeper | Today at 12:43:07 am
My tuner just noticed that I was hitting my transfer case torque limit...
Re: For those looking for something different for a 2nd (or 3rd) car
by FoMoCoSHO | May 26, 2020, 11:23:21 pm
There is another CON if you are a DIY type...The packaging is slick bu...
Re: Thinking of trading the 16S H O
by Gjkrisa | May 26, 2020, 09:28:19 pm
I almost bought a dodge/jeep/Chrysler product once....nah I didn'...
Re: Does anyone here have a Taurus 2.0 EB?
by GhostlyGrenade | May 26, 2020, 07:35:35 pm
They must be giving SCT devices away. There's no way people are s...
Re: MRT blues
by StinkinLinkin13 | May 26, 2020, 04:32:36 pm
We'll my four muffler setup is a winner for me. Its not pretty ri...
Ecoboosted Gallery!!
by StealBlueSho | May 26, 2020, 11:27:31 am
Add a picture of your ecoboost or your favorite ecoboosted picture! It...
Re: MrHighCALiber's SHO Forged Engine Build
by 802SHO | May 26, 2020, 05:15:44 am
That's crazy!  Looks like she won't be down for long in...
Re: EBPF Under New Ownership!
by 76fomoco | May 25, 2020, 12:19:53 pm
SBS thanks for picking up the torch and keeping this wealth of informa...
Re: EPP CAI
by 802SHO | May 25, 2020, 05:58:21 am
I ordered mine last week and it's sitting on the bench. I figured...
Re: Letís talk weight reduction?!
by 802SHO | May 25, 2020, 05:42:56 am
I think it's worth it for a couple reasons...first being youre fa...
Re: Ford Recalls
by BlueSHO | May 24, 2020, 11:16:02 pm
FORD EXPLORER RECALL: SUSPENSION PROBLEMS IN 1.2 MILLION SUVS. Z ...
Re: Brake Cooling Kit
by bpd1151 | May 24, 2020, 07:55:43 pm
None that I've found. Although I do employ the Titanium heat shie...
Back to top
