May 27, 2020, 12:54:43 am
Author Topic: Boost leak help  (Read 6102 times)
Offline ecoboostsho
  • Forum Supporter!
  • Minneapolis, MN
  • -Given: 208
  • -Received: 248
Re: Boost leak help
« Reply #15 on: October 03, 2019, 04:54:31 pm »
Welp following up, went back to 91 to eliminate any fuel trims from that, and had a buddy come over Saturday night to troubleshoot. Installed my boost leak tester, pressured up to 5 psi and you could hear a faint noise. Went to 10 and it was very apparent that we had a leak.
Turned out the boot T-clamp popped off the rear turbo which was affecting wastegate readout. All fixed!
Follow up ? How do you test for boost leaks on a twin turbo setup like the SHO? I've seen some YouTube videos where you cap off the turbo and pressurize everything but assume you would have to do it to both turbos? Or is there another way? TIA
Sent from my Pixel 3 XL using Tapatalk
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • New York SHO
  • -Given: 1932
  • -Received: 4056
Re: Boost leak help
« Reply #16 on: October 05, 2019, 06:52:12 pm »
There are many reputable shops that perform a Smoke test! Bottle of soap is another alternative with water preferably kids (Mr Bubbles) and spray around the engine bay until you notice any bubbles forming. Z
Here's the PIC of the TURBOCHARGER VACUUM HOSE LINE TUBE AKA - Rubber Valve Assembly as mentioned earlier for reference..I'm just TOL
https://fordpartsgiant.com/parts/ford-valve-asy-rubber_dg1z-9961-a.html?Vin=1FAHP2KT5DG183206&Filter=()&Location=turbocharger,,9961
« Last Edit: October 05, 2019, 06:55:48 pm by ZSHO »
Offline ecoboostsho
  • Forum Supporter!
  • Minneapolis, MN
  • -Given: 208
  • -Received: 248
Re: Boost leak help
« Reply #17 on: October 05, 2019, 07:52:57 pm »
Thanks *. Well my car is actually running just fine now stock. It fixed itself at some point which bugs me even more. I'm leaving it alone for now although I still feel the wastegates duty is high to maintain stock boost levels. I will probably go back to tunes and see if it can keep up.
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • New York SHO
  • -Given: 1932
  • -Received: 4056
Re: Boost leak help
« Reply #18 on: October 12, 2019, 08:00:05 am »
I guess you can always try to (pinch) the wastegate hose leading to the wastegate with locking pliers in order to determine if one of your Turbos are going bad!
If you notice the Boost level is back to normal during this procedure then one of your turbos need replacing and remove the pliers..
I would also try to rule out a plugged CAC.
It's a bit of Trial & error and proceed with CAUTION rule may apply!!  Z
« Last Edit: October 12, 2019, 08:04:10 am by ZSHO »
Offline ecoboostsho
  • Forum Supporter!
  • Minneapolis, MN
  • -Given: 208
  • -Received: 248
Re: Boost leak help
« Reply #19 on: October 12, 2019, 09:42:58 am »
Thanks Z. I've been patiently troubleshooting the last week. I've ruled out the TIP and MAP sensors unfortunately because those would have been easy. I took my air compressor and pressurizes the hose leading to both wastegates with about 12 psi and both wastegates moved and I verified there weren't any slow leaks so the hoses and connections are solid. I got both wastegates to physically move however the back one make a slight noise which makes me think it may be sticking.
I do have some general questions I'm hoping someone can answer specific to the Ecoboost. Are the wastegates normally closed or open? I know when the car hits 100% duty cycle on the boost solenoid that  I thought it was sending boost to the wastegates to close them fully so the turbos spin up. Since these are pressure actuated that would mean they are open normally? Or am I getting this backward LOL...
Unless the boost solenoid is bad I most likely have a sticking rear turbo wastegate.
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • New York SHO
  • -Given: 1932
  • -Received: 4056
Re: Boost leak help
« Reply #20 on: October 12, 2019, 03:04:22 pm »
The wastegates should be in the closed position AFAIK!
In your case it sounds like one or more wastegates are maybe stuck open or sticky wastegate.
The noise your hearing could be related to your issue!
I would also try to disconnect the PCM connectors and inspect the wiring harness for corrosion and clean it with some electronic or air mas flow cleaner.
Car wash (auto) or heavy rain recently! Z
[PDF BELOW]
https://drive.google.com/file/d/0B8JUL90DXgdidFg4ZmN6SzF3cVVueGo2TFNSNUtfamJPcllN/view?usp=drivesdk
« Last Edit: October 12, 2019, 05:07:10 pm by ZSHO »
Offline autox4fun
  • Jr. Member
  • Kalamazoo, MI
  • -Given: 21
  • -Received: 18
Re: Boost leak help
« Reply #21 on: October 17, 2019, 07:18:43 pm »
[PDF BELOW]
wastegate at 100% is the pcm requesting boost and closing the valve to prevent movement of the actuator.
0.00 is rest position, or just wastegate spring only
(this is the way it was told to me)
Offline ecoboostsho
  • Forum Supporter!
  • Minneapolis, MN
  • -Given: 208
  • -Received: 248
Re: Boost leak help
« Reply #22 on: October 17, 2019, 07:53:00 pm »
[PDF BELOW]
Thanks for the reply and this makes total sense. I guess I was thrown off by a few posts on the other forum which said the c clip fell off their wastegates actuators and they had low boost. I thought to myself shouldn't they have high boost since the wastegates wouldn't open? Anyway I've ruled out the TBCP (TIp pressure sensor), the MAP sensor, IAT sensors, and the turbo charger boost solenoid, the BOV's, along with the lines that lead to the wastegates. I either have a big boost leak someplace (which I can't hear) or the wastegates are sticking open. I believe it's the latter unfortunately because the back one makes a weird sound when I artificially open it with compressed air. I've got an appointment at the dealer next Friday. I may have a local shop throw a boost leak detector on it first just to rule that out but I do have hot pipes and they seem Rock solid as I've checked the boots and clamps...
Offline ecoboostsho
  • Forum Supporter!
  • Minneapolis, MN
  • -Given: 208
  • -Received: 248
Re: Boost leak help
« Reply #23 on: October 17, 2019, 08:02:16 pm »
Wait a minute I think I get it...if the c clip pops off then the wastegates spring is still in play correct? So you'd see some boost but not only up to spring pressure...
Offline ecoboostsho
  • Forum Supporter!
  • Minneapolis, MN
  • -Given: 208
  • -Received: 248
Re: Boost leak help
« Reply #24 on: October 17, 2019, 09:58:32 pm »
Upon further review I've definitely found a problem. The front turbo wastegates actuator is no longer connected to anything...Its buried under the exhaust manifold and while I can get my fingers under there I can't get it from the topside by feel. It might be missing an entire pin and clip? Here is the only shot I could get of the end of the wastegate actuator attached to well... nothing from what I can tell  The rod also has play in it up and down which further adds to the it's not attached ..maybe I can get to it from the bottom?
Offline TopherSho
  • Eugene Oregon
  • -Given: 483
  • -Received: 366
  • 1st boosted rig!
Re: Boost leak help
« Reply #25 on: October 17, 2019, 10:47:05 pm »
Rent a lift?  That would explain a few things ..
Offline Jordan
  • Columbia, Mo
  • -Given: 224
  • -Received: 642
  • I'm the captain of this SHIP
Re: Boost leak help
« Reply #26 on: October 17, 2019, 11:49:42 pm »
That would cause a lack of boost LOL! Glad ya found it
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • New York SHO
  • -Given: 1932
  • -Received: 4056
Re: Boost leak help
« Reply #27 on: October 18, 2019, 06:53:16 am »
Glad you found it! Is it still under warranty!
Remove both Front and rear under- cover. PICS Below.  Z
« Last Edit: October 18, 2019, 07:00:04 am by ZSHO »
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 12953
  • -Received: 4203
Re: Boost leak help
« Reply #28 on: October 18, 2019, 07:36:23 am »
C Clip
Offline ecoboostsho
  • Forum Supporter!
  • Minneapolis, MN
  • -Given: 208
  • -Received: 248
Re: Boost leak help
« Reply #29 on: October 18, 2019, 08:36:31 am »
C Clip
Thank you!  I am going to have to buy some different sizes and see what fits but that should get me close.
* Featured Topics
* Recent Topics
Re: Transfer case torque limit
by 10sleeper | Today at 12:43:07 am
My tuner just noticed that I was hitting my transfer case torque limit...
Re: Updated Gallery Capabilities
by bpd1151 | May 26, 2020, 11:53:43 pm
The (several) hundreds of pics I had stored in/with that hosting site,...
Re: For those looking for something different for a 2nd (or 3rd) car
by FoMoCoSHO | May 26, 2020, 11:23:21 pm
There is another CON if you are a DIY type...The packaging is slick bu...
Re: 802SHO 2010 Build
by FoMoCoSHO | May 26, 2020, 11:08:36 pm
Pretty sweet upgrade for us Gen IV saps even without the porting.The e...
Re: Thinking of trading the 16S H O
by Gjkrisa | May 26, 2020, 09:28:19 pm
I almost bought a dodge/jeep/Chrysler product once....nah I didn'...
Re: Does anyone here have a Taurus 2.0 EB?
by GhostlyGrenade | May 26, 2020, 07:35:35 pm
They must be giving SCT devices away. There's no way people are s...
Re: MRT blues
by StinkinLinkin13 | May 26, 2020, 04:32:36 pm
We'll my four muffler setup is a winner for me. Its not pretty ri...
Ecoboosted Gallery!!
by StealBlueSho | May 26, 2020, 11:27:31 am
Add a picture of your ecoboost or your favorite ecoboosted picture! It...
Re: MrHighCALiber's SHO Forged Engine Build
by 802SHO | May 26, 2020, 05:15:44 am
That's crazy!  Looks like she won't be down for long in...
Re: EBPF Under New Ownership!
by 76fomoco | May 25, 2020, 12:19:53 pm
SBS thanks for picking up the torch and keeping this wealth of informa...
Re: EPP CAI
by 802SHO | May 25, 2020, 05:58:21 am
I ordered mine last week and it's sitting on the bench. I figured...
Re: Letís talk weight reduction?!
by 802SHO | May 25, 2020, 05:42:56 am
I think it's worth it for a couple reasons...first being youre fa...
by 802SHO | May 25, 2020, 05:27:29 am
Man that flywheel ssssure issss perrrtyyy Sent from my LM-G710VM using...
Re: Ford Recalls
by BlueSHO | May 24, 2020, 11:16:02 pm
FORD EXPLORER RECALL: SUSPENSION PROBLEMS IN 1.2 MILLION SUVS. Z ...
Re: Brake Cooling Kit
by bpd1151 | May 24, 2020, 07:55:43 pm
None that I've found. Although I do employ the Titanium heat shie...
Back to top
