- RotM Winner
- Elite Member
- Boosted
- Logged
Yeah I mean if this was installed my car I would have a data log to share compared to before the spacer and after showing a timed idle heat soak and some sort of WOT data before and after installation of the spacer all other mods being equal and similar ambient temp. So I'm just so puzzled that you posted this on FB and said...after towing for a bit uphill IAT2 was 90° cooler than coolant temp...and that's it?
Just for all the waiting and waiting ..for this...that's first look? Great. I have no clue how much better it is. None, zip, zilch lol!
Hopefully not offending anyone but I mean if I was the lucky revealer I would have nailed the key performance benefits for being either an advantage or inconclusive but more specific and in line with what the spacer is used for. Right now we "think" if you tow often...it could be better now?
I would really hope somone would bust my balls if the shoe was on the other foot.
Sent from my LM-G710VM using Tapatalk
