Phenolic Spacers
Started by MKS Tom, July 28, 2019, 11:06:00 AM
MKS Tom
I had brought this up on one of the FB groups but figured I would here as not everyone uses social media.  The ones in the picture are from a Subaru SVX, I have them on mine.  I know the guy who has made them for us in that community for over a decade and he seems willing to make them, just needs a manifold.  Who would have an interest in these (obviously Jordan lol)?  I would think they would be useful for the track guys.  They do a good job on my SVX (when it runs) to cooling down the manifold.
2013 Lincoln MKS ecoboost, 70,000 miles.  3 bar map 93 tune (E30 in the future) by both AJP Turbo and Ortiz Performance.  PPE catted down pipes, EPP dual CAI (not yet installed so K&N drop in), .026 gapped SP542, 170 degree thermostat, Dynomax axlebacks, and Power Stop Z23 pads and rotors.
If you could download the image and upload into your post, everyone will be able to see it :)
In case the fb link goes away :)
MKS Tom
Weird, it doesn't seem to allow you to upload a pic from your device.  I was able to link it though by going into the link once more and using that link.  That or I don't know what I'm doing.  lol  Seems to be posted now, though it is mainly for a reference.
Jordan
To add to this and what these do. Essentially the way the cast aluminum intake manifold is "spaced" from the head we get a metric ton of heat transfer into the intake manifold causing mega heat soak. This creates a divide between the two and will help keep IAT2's down which is HUGE on these cars.
Blackhawk
4sfed
How thick would they need to be for our application?  Could we buy raw material, do some gasket matching, and cut them ourselves?
2015 SHO, GH E30 tune, GH intercooler, 3 bar, SP542's, PPE Cat'd DP's, XDI-35, H&R springs, AD Gen2 mounts
Factory Five Mark III, 2004 Mach I donor (gone)
2003 Mustang Cobra 'vert, 456 rwhp, with mods (gone)
2002 MB C32 AMG (gone)
1997 Cobra 'vert, Vortech'd (gone)
I believe the Intake manifold are Aluminum IIRC! Great way to reduce heatsoak! Z
Gray Brick
I used phenolic spacers on my Mustang many years ago... worked great!!!
With the IAT temps on these cars skyrocketing in traffic it would be a big help.
I would be interested in purchasing one of these for my Flex if they can be produced.
I put the same question on this forum 2 years ago:
https://www.ecoboostperformanceforum.com/index.php/topic,6894.msg106068.html#msg106068
2013 Ecoboost Ford Flex
FiveLeeter918
- Lee
Ortiz Performance Vendor Forum | Find us on Facebook! | Shop Today!
Gofspar
definitely interested in this.
AJPTurbo E30 3bar rev4, SP-534 .28, MSD coils, reische 170 tstat, ARH Catless DP, resonator delete, magnaflow mufflers, airraid CAI, H&R sport springs, UPR Catchcan /w CCS, SSM "Street" RMM
MKS Tom
My Subaru friend is interested in doing this.  He just needs a manifold to borrow and people have already offered that.  I am hopeful this goes some place for everyone as I know a lot of you track guys could use this.
802SHO
I would definitely buy these too!
SM105K
4sfed
I too am interested.
