bpd1151's 2010 SHO Rebuild Thread....
Started by bpd1151, July 24, 2019, 12:03:50 PM
El_SHO
Quote from: bpd1151 on August 09, 2019, 03:00:28 PM
08/09/2019 --- Ordered the new PTU replacement and the Police Interceptor alternator for my SHO.
BOTH are due in early next week.
Alternator will sit and collect dust so to speak, while other aspects keep chugging along.
Can you confirm PI 220 amp alternator works and fits and works 13 sho w/pp?
2013 Taurus SHO with PP
Unleashed 93 oct (Livewire TS)
170° Tsat
K&n drop in air fliter
2 12in q5000 subs + 5000(2800rms) SSL amp @ 1 ohm
All indications I've seen thus far, yes.
I won't know definitively until everything gets reassembled.
I'll repost when that occurs to provide you with confirmation.
General Specifications
Item    Specification
Generator (2.0L GTDI, without climate control seats)
Rating    175 amps
Output    106/178 amps (max) @ 700-2,000 engine rpm
Pulley ratio    2.44:1
Generator (2.0L GTDI, with climate control seats)
Rating    200 amps
Output    117/207 amps (max) @ 700-2,000 engine rpm
Pulley ratio    2.44:1
Generator (3.5L GTDI, early production)
Rating    200 amps
Output    109/191 amps (max) @ 600-2,000 engine rpm
Pulley ratio    2.66:1
Generator (3.5L GTDI, late production)
Rating    175 amps
Output    88/175 amps (max) @ 600-2,000 engine rpm
Pulley ratio    2.66:1
Generator (3.5L Ti-VCT)
Rating    175 amps
Pulley ratio    2.66:1
Generator (Police)
Rating    220 amps
Output    103/217 amps (max) @ 600-2,000 engine rpm
Pulley ratio    2.67:1
https://www.fordpartsgiant.com/parts-list/2013-ford-taurus/alternator-and-mountings.html
Alternator Assy
Ford DG1Z-10346-A
DG1Z-10346-A
Alternator Assy
175 AMP
Fit Note:
Heavy Duty Alternator, Standard Duty Alternator
Production Date:   02/2012-07/2012
Fitting Vehicle Options:
(-) Police Version, 6 Cyl 3.5L Cyclone Petrol TIVCT, 6 Cyl 3.5L DOHC T/C... ...View More
Callout Name:   10346
Replaced by:   DG1Z-10346-F
$473.35$285.77
Ford DG1Z-10346-B
DG1Z-10346-B
Alternator Assy
200 Amp
Fit Note:
Base Number:   10346
Callout Name:   10346
$671.16$404.55
Ford DG1Z-10346-C
DG1Z-10346-C
Alternator Assy
220 Amp
Fit Note:
Extra Heavy Duty Alternator
Police
Base Number:   10346
Callout Name:   10346
Replaced by:   GB5Z-10346-C
$781.29$470.67
Ford DG1Z-10346-D
DG1Z-10346-D
Alternator Assy
200 Amp
Fit Note:
Alternator - 175A, HEAVY DUTY PLUS ALTERNATOR
4 Cyl 2.0L EcoBoost (240PS)
Base Number:   10346
Callout Name:   10346
Replaced by:   G2GZ-10346-B
$818.18$488.78
Ford DG1Z-10346-E
DG1Z-10346-E
Alternator Assy
175 AMP
Fit Note:
Base Number:   10346
Callout Name:   10346
Replaced by:   G2GZ-10346-C
$818.18$488.78
Ford DG1Z-10346-F
DG1Z-10346-F
Alternator Assy
175 AMP
Fit Note:
Production Date:   07/2012-
Base Number:   10346
Callout Name:   10346
$473.35$285.77
FU2Z-10V346-MRM
Alternator Assy
175 AMP , Motorcraft , Ford Retail Spec , Remanufactured
Fit Note:
(-) Police Version, 6 Cyl 3.5L Cyclone Petrol TIVCT, 6 Cyl... ...View More
Callout Name:   10346
Replaced by:   FU2Z-10V346-ALRM
$236.67$144.45
HU2Z-10V346-BARM
Alternator Assy
Fit Note:
Callout Name:   10346
$335.58$201.71
HU2Z-10V346-CDRM
Alternator Assy
Fit Note:
Callout Name:   10346
$438.96$263.68
Well. Taking advantage of an unusual, near 50 degree here in CHItown, I opted to wash the SHO for the literal 1st time since April of 2019.
Boy, was she filthy AF. Just take a look.....
Glad to have been able to clean her up.
And, I might add, this right here is..... bar none, the (literal) BEST MOD I've performed to date.
Good riddance.......
802SHO
Quote from: bpd1151 on January 14, 2020, 10:23:44 PM
Liberating .......Who will pick up the reins to this BEAST?
Black Dream
Quote from: 802SHO on January 15, 2020, 08:41:44 AM
Lol looking at your previous posts I wondered how long it would take you to scrape that crap off. And now I have my answer, good riddance I say!
Sent from my LM-G710 using Tapatalk
2010 MKS Eco, Airaid, SCT X4, Unleashed, SP542 plugs, 3 bar MAP and current daily.
2006 Pontiac GTO M6, 1 of 101 exactly like her, bone stock, lost to flood 5/19, gone but not forgotten....
TopherSho
Hey I was curious .. Any head mods going in for flow?  Been super curious if better flow would allow for another 400-500 rpm ..
Best 0-60 public road 4.35s
Quote from: TopherSho on January 17, 2020, 01:08:18 AM
Yes.
As far as specifics? I am not able to disclose at this time.
But that info will be being spoken about eventually.
TopherSho
Hooey pricey pricey! Today I ordered the OCC from UPR.
Along with all possible/available upgrades.
Crirmeny. Sure hoping its worthy of the investment.
One more piece of the equation.
StealBlueSho
Placed an email inquiry to x35 Designs, in regards to their new product offering (Phenolic Spacers) and expressed willingness to pay in full immediately, to facilitate a quick turn around.
Also, received data from the machine shop owner this morning regarding flow data on BOTH the Intake, and the Exhaust ports, for all of the extreme custom porting work that has been performed on my heads.
The data displays 'BEFORE' and 'AFTER' #'s for public consumption. I have been told this improvement (a nearly 26% increase on the intake side, and 44% increase on the exhaust side) is projected to provide an 80 to 85hp improvement on just this one modification alone.
Getting more excited as the clarity and culmination of several months worth of work, is beginning to show HUGE improvements in many areas.
Hope everyone's New Year is off to a great start! Enjoy!
02/08/20......
Heads are nearly complete.
Machine shop owner began researching cams, and pretty much came up empty handed.
As such, we have decided to roll with custom, upsized/enlarged valves, to make up for a slight anticipated cfm loss from a replacement stock cam not being able to hit the peak flow #'s achieved from the custom porting.
The aforementioned netting us a slight gain. Which is great.
Having a few more items thermal coated.
Assembly work beginning soon, and more engine porn pics should be forthcoming.
Re-visited / re-discussed turbo's again. Still being told to stay put with the ATP's (for now). There's some curiosity in where they'll max out as it relates to my build specifically.
The expectation is we will max them out, and when that occurs, we'll re-approach and will go with a completely custom, one-off turbo set up in the future. Which is fine, as it'll give me time to work more O.T. and save up $$$$$. Likely have to modify the DP's at that time as well.
Ummm..... what else?
Being told the trans vendor's waiting on a few more parts. But it's coming along. Also was told that the trans was in much better shape than the vendor anticipated. Stated there was some minor scoring on the trans pump itself, but otherwise, all else checked out good. Still, the trans vendor knows my desired goals, and is doing their best to build something decent that'll take the anticipated abuse. Fingers crossed.
Received the UPR dual OCC. All aspects of the kit appear well built, beefy/sturdy.
Looks like we'll be rolling with an SCT based tuning device. Likely gonna get the 'Livewire +TS' or whatever the latest offering is.
A continued work in progress. I'll post pics as they are provided to me. Hope everyone's doing well.
