October 15, 2019, 09:47:06 PM
Author Topic: rough idle no accel response and P0087 code  (Read 1596 times)
Offline lamrith
  • : PNW
  • -Given: 106
  • -Received: 372
« on: July 13, 2019, 02:49:36 PM »
Title pretty much sums it up, wife was driving today and the car died on her.  She said it stopped respond to pedal and then died.  Thankfully she coasted to side of road safely.  I had her try pull codes and it gave her none.  I ran out there hit starter and took long time to start then idled rough.  I pulled codes and P0087.  Not sure if it could be related, but I had a P0627 code pop up randomly 2 months ago, then it popped up a week after than and nothing since.  Only code now is P0087.
Quick search here and it seems that might be a TSB related to P0087, but also chances it is;
  • LPFP and sender (PN DA5Z*9H307*F)as the gasket set (PN 4L3Z*9276*AA)
  • Fuel pump module ( anyone have a part number?)
Since I am tuned I am doubting a reflash of factory updated tune per the TSB is going to fix it?  It is probably "mechanical" (failed hardware) in some way?
Is there a way to diagnose if it is the fuel pump/module vs a bad injector?  We have had a few bad injectors on board in the last year and my biggest concern is nuking the motor from hydrolock.  I have no problem doing a fuel pump myself, but if I take it to a dealer to have them run thru it to diagnose it then I am really stuck with them and at their mercy and I am not a fan of that for something I can diagnose and fix myself.
« Last Edit: July 15, 2019, 05:14:59 AM by lamrith »
'13 Sho PP, SCT x4, AJP 92-Octane rev6 (14psi&20spark) NGK 6510, 3Bar, K&N CAI, PPE Catted DP, Dynomax Axleback, 20*9.5 Voxx Lago.
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • : New York SHO
  • -Given: 1682
  • -Received: 3640
Re: rought idle no accel response and P0087 code
« Reply #1 on: July 13, 2019, 03:11:08 PM »
It sounds like it's your Fuel pump control module!  Recall performed!
Glad no one was injured during this ordeal! Z
 AA8Z-9D370-B  - $42.73
[RECALL PDF BELOW]
https://drive.google.com/file/d/0B8JUL90DXgdiaWxocmdhUnEteTdQbmdTbDJzU3BKLXpFZzQw/view?usp=drivesdk
https://www.fordpartsgiant.com/parts/ford-module-engine-fuel_aa8z-9d370-b.html?Vin=1FAHP2KT5DG183206&Filter=()&Location=relays,,9D370
« Last Edit: July 13, 2019, 03:23:23 PM by ZSHO »
Offline lamrith
  • : PNW
  • -Given: 106
  • -Received: 372
« Reply #2 on: July 13, 2019, 03:23:22 PM »
[RECALL PDF BELOW]
Thanks Z!!
Is there by chance a way to lookup online if that recall has been done on my car?
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • : New York SHO
  • -Given: 1682
  • -Received: 3640
« Reply #3 on: July 13, 2019, 03:28:33 PM »
Do you have an account! If so simply Register/Sign in by using your Vin number. Z
https://owner.ford.com/tools/account/maintenance/recalls.html?pagename=Owner/Page/RecallsPage%3fgnav=footer-owner
« Last Edit: July 13, 2019, 03:35:37 PM by ZSHO »
Offline lamrith
  • : PNW
  • -Given: 106
  • -Received: 372
« Reply #4 on: July 13, 2019, 03:33:12 PM »
Do you have an account! If not simply Register using your Vin number. Z
YOU D MAN Z!!
Looks like the only thing outstanding on my vehicle though is the APIM Warranty extension.
Field Service Action Number: 12M02
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • : New York SHO
  • -Given: 1682
  • -Received: 3640
Offline SHOdded
  • Administrator
  • : Beltsville, MD
  • -Given: 11865
  • -Received: 3893
« Reply #6 on: July 13, 2019, 04:33:35 PM »
Helpful thread
https://www.ecoboostperformanceforum.com/index.php/topic,4974
Since it is so easy to get to, take a pic of what you got.  Dunno if it will have a production date stamp on it, but replacing it yourself is super easy.
Offline lamrith
  • : PNW
  • -Given: 106
  • -Received: 372
« Reply #7 on: July 13, 2019, 06:29:50 PM »
Helpful thread
You thinking it might actually be the HPFP instead of the LPFP or relay?  I will post some picts in a few min.
Offline lamrith
  • : PNW
  • -Given: 106
  • -Received: 372
« Reply #8 on: July 13, 2019, 06:35:57 PM »
Plugs are all dry.  How long would it take for them to be dry if I had bad injector??  It has been a few hours since the car last ran.
My concern is bad injector and hydrolock.  Injector replacement is out of my wheelhouse.  Pumps and relays I can do here at home..
Plug order per picture
2 1
4 3
6 5
Sent from my SAMSUNG-SM-G935A using Tapatalk
Offline lamrith
  • : PNW
  • -Given: 106
  • -Received: 372
« Reply #9 on: July 13, 2019, 06:44:27 PM »
Part of my concern is that the P0087 code for low pressure was because an injector was stuck open, and the fuel pump could not keep up which is why I keep bringing that concern up, maybe I am just overthinking it?  There was zero fuel smell out of any of the cylinders or from any of the injectors.
Offline TopherSho
  • : Eugene Oregon
  • -Given: 477
  • -Received: 306
  • 1st boosted rig!
« Reply #10 on: July 13, 2019, 08:50:57 PM »
as a recent victim myself, your oil would smell ...
Offline lamrith
  • : PNW
  • -Given: 106
  • -Received: 372
« Reply #11 on: July 13, 2019, 09:34:43 PM »
Mine does not, I have no fuel smell anyplace.  I will start with the relay module and go from there.
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • : New York SHO
  • -Given: 1682
  • -Received: 3640
« Reply #12 on: July 14, 2019, 03:47:21 AM »
2 1
4 3
6 5
I think SHOdded meant PICS of the FDM behind passenger rear seat!
The plugs look overly well done!
R those the original spark plugs! Some new COP are in order
 Z
« Last Edit: July 14, 2019, 03:56:56 AM by ZSHO »
Offline lamrith
  • : PNW
  • -Given: 106
  • -Received: 372
« Reply #13 on: July 14, 2019, 07:29:44 AM »
Those are NGK LTR7I-11 plug they are year and half old.  They have a tapered electrode and ground bar like that from the factory if you are thinking that is errosion.  There are no signs or erosion or degradation of the electrode or ground bar on eh ones I have pulled, they are still crisp and uniform in shape.
But yes since the are out, I plan to replace them.  I will say the boot lubricant I used when I did the plugs a year ago has worked wonders.  the plugs AND boots slid right off with zero problems.  MUCH nicer than the 10rnd battle royal I had with the original ones.
Offline lamrith
  • : PNW
  • -Given: 106
  • -Received: 372
« Reply #14 on: July 14, 2019, 09:21:07 AM »
Quick follow up.  I put plugs back in and put everything back together.  Got the Livewire display reconfigured so I could see rail pressure.  Pretty sure the LPFP or Module is bad.  Could not get over 11psi fuel pressure, that tells me the HPFP is not getting anything as I bet the LPFP puts out more than 11psi if it is working.
* Featured Topics
* Recent Topics
by Gofspar | Today at 08:56:02 PM
Also it's extra bad if I go around a corner and apply some heavy ...
Re: Meth and bank imbalance?
by bamsho | Today at 06:17:18 PM
My single port Alky Controls with M15 nozzle, both banks on my '1...
Re: Help with codes
by ZSHO | Today at 06:05:58 AM
Since you have a 2010MY inspect the wiring for any chaffing or corrosi...
Re: Newbie first time in a Ford!
by SHOdded | Today at 12:26:34 AM
Anti-spam measures.  We get hit hard and often LOL.  Should ...
Re: Splitter
by 802SHO | October 14, 2019, 02:23:41 PM
Dropped the splitters off for corner rounding.  Should have them ...
Re: Rear upper control arms?
by SHOdded | October 13, 2019, 02:16:52 PM
What year is your Flex?  I am including the procedure for a 2011,...
Re: New PB 11.8947 Gearhead E30
by 802SHO | October 13, 2019, 08:36:08 AM
Congrats man and welcome to the 11's buddy!...
Re: Snow Pics!
by Gjkrisa | October 12, 2019, 11:56:20 PM
Here's a neat picture of the ice on her in the woods https://uplo...
Re: Boost leak help
by ZSHO | October 12, 2019, 12:04:22 PM
The wastegates should be in the closed position AFAIK! In your case it...
Re: PPE Updated Downpipes
by 76fomoco | October 11, 2019, 08:11:46 PM
I too would like to delete the 3rd cat so post back with your DP'...
Re: End of an era!
by 76fomoco | October 11, 2019, 08:05:10 PM
man I would love to by this hood!...
by 76fomoco | October 11, 2019, 08:01:20 PM
KEEPEM COMING!...
Re: Check engine flashing, fuel smell, limp mode, and now no start
by StinkinLinkin13 | October 11, 2019, 02:27:04 PM
Awesome. Congratulations and great job! 🍻...
Re: 2014 pp driveline in 2010 sho questions.
by Spyder3000gtvr4 | October 11, 2019, 10:00:01 AM
Havenít had time to look at the car again will try this weekend. Will ...
Re: Throttle body size for Taurus SHO?
by ddlopes | October 11, 2019, 09:11:49 AM
Looks like the BBK may need to be modded to work properly... according...
Back to top
