- RotM Winner
- Elite Member
- Boosted
- Logged
The obd scan tool isn't the same thing as your handheld tuning device. Both can read and clear codes but what you specifically need the scan tool for is to check the I/M readiness status for emissions. By having that tool and checking the I/M readiness status you'll know if you will pass or fail an inspection before you actually go to get it done. Just a nice tool to have. You don't have to buy one though. You can probably go to any parts store in your area and simply ask for them to check your I/M readiness status and they can do it for free. You want the I/M readiness status to read 0. Not sure what the standard is in all states but in VT it can read 1 and you will still pass. Then its just a visual inspection here in VT...my guy "didn't see" anything wrong lmfao🤘
