SM105K's Ownership/Performance/Maintenance Thread
Started by SM105K, June 26, 2019, 03:42:41 PM
SM105K
Quote from: 802SHO on August 12, 2019, 06:58:36 PM
I can't wait to see it all done!  The cooler will work just will it work better than the factory PP cooler?  Guess we'll see.
The ST will really try to kill you now that you're letting it breathe
The SHO should look pretty sharp, and the ST...well it will just be...itself. Just worse.
FLEXXX
#121
I use a NOS progressive mini controller. I can set it for each gear or boost or just rpm for activation and ramp up / down. I have 150shot jets in it (.056n  .048f) but have the max set to 80%. I ran about a half dozen bottles (15# bottles)through the stock 120k motor before I put my new one in. never had a issue, just got to be smart and safe on tune and ramp aggression. I have not sprayed the new motor combo yet as I am still working on getting everything out of it first.  I don't think you should have any problems.
Motor, turbo's, exhaust, intake, nitrous, W/M blah blah blah
SM105K
Quote from: FLEXXX on August 13, 2019, 10:03:18 AM
Thanks for the info. I am probably going to throw a kit on the car just because. Once I do I will decide which route will be the best and go from there.
FWIW - As long as your pocket is happy proceed! Best of luck with the Mods and all cause take it from me it never ends. Z
SM105K
Quote from: ZSHO on August 13, 2019, 11:01:18 AM
It certainly will be fun, for both vehicles. Thanks for the kind words Z.
802SHO
Must have some deep pockets buddy lol!  I'm definitely on board with having nitrous....just bc!
SM105K
#126
Quote from: 802SHO on August 13, 2019, 02:18:56 PM
I wish I had deep pockets lol.  When it comes to cars....I don't have a problem spending money.  When it comes to everything else...esp clothes I become Scrooge.
Also, I have been fortunate enough to find exception deals here and there.
Quote from: SM105K on August 13, 2019, 02:36:19 PM
Well you can afford to be a Scrooge when it comes to expanding your wardrobe, or in your specific case *NOT*......
Fortunately you workout, so you can pull off wearing the banana hammock only wherever you go.
Bwahahahaha
802SHO
SM105K
76fomoco
Quote from: bpd1151 on August 13, 2019, 02:53:53 PM
Bwahahahaha
Why do we only have a "Thank you" button?
I would like to see the "No Thank YOU" button to help Un visualize what BPD just did to all of us.
2013 PP AJP E30 160 TS, sp542 plugs, 3 bar, PPE catted DP's, GH IC, GH turbos, XDI-35, EPP hot and intake
Best 3-29-21  11.85 with 3000 DA
DA trap best 117.96
E30 = 492 whp, 536 wtq
E30+meth 498 whp, 539 wtq
Bwahahahahahahaha......
That's flip'n HILARIOUS 76!
SM105K
Just got confirmation that The Go Cart's downpipe was delivered today!  So Operation Silence Is Deadly will commence this weekend.  New strut bearings, new downpipe, updated big boost E51 tune, and a fresh oil change should make The Go Cart a bit more.......Anghellic.
802SHO
SM105K
All the parts arrived for the ST. I will tear it apart tomorrow morning. I am really impressed with the Megan Racing Downpipe. If it fits like it is made, then it is a complete steal of a price for an upgrade. $174 shipped to my house, arrived 2nd day shipping.
