- RotM Winner
- Elite Member
- Boosted
- Logged
Quote from: SM105K on November 18, 2019, 08:53:11 AM
Couple of things.
I took the ST to CA this weekend. I have the AJPTurbo Flex Fuel Tune and well...... This is the first time I have actually got to put E85 in it. Holy crap what a difference. Ford really did it right with the ST and its ability for the tuners to be able to do things like this. However they really dropped the ball on the SHO.
Couple of takeaways.
When I run 87 octane it gets the best mileage by far. I use 87 on the long drives. I cruise at 91 mph in AZ, and 81 mph in Ca. Car gets roughly 25 mpg at that speed and really never see much boost unless I am passing. Even when I the car sees boost there is no knock. I have seen as high at 29 mpg at the proper speed limit. I don't want nor do I have the time to drive the proper speed limit, and either does anyone around me either.
I run 91 octane during the non summer months with a lot of freeway driving 70/30 split with in town driving. The ST is my daily. I am averaging just at 24 mpg with my peppy driving. The best I have netted is 27 mpg with non boost boring driving. Since the air is colder now I lean towards 91 because it makes great power and for my driving on the freeway it gets the mileage for my boost happy right foot.
I run E54 during the summer. I don't want to change my driving fun because of knock so she gets the corn during the summer heat. The mileage suffers, but the performance and my happiness remains. Best I can scrape with my normal peppy driving is 20 mpg. Mileage really suffers if I use my right foot heavy. I have seen it as slow as 18.5 mpg.
I ran a tank of E85 in Ca this past weekend. In CA E85 is readily available, in AZ only E54 is. Holy crap what a difference. The car was pretty stupid. Way noticeable power and a riot to drive. However, on long stretches of sustained 82 mph, she could only muster 19 mpg. However...the smiles per gallon were worth it. E85 was $2.89 a gallon, and 87 was $3.89. I probably broke even in price point per mpg but to see what the car can do on all fuels is pretty damn cool. Also I had ZERO cold start issues on E85 in low 30 degree weather as well. So that is always a plus!
Hats off Brad...once again you killed it.
For the SHO:
The splitter arrived and I will be working with Andrew (802SHO) on a couple of things with it. Should be fun. Looking to do a couple of things to the SHO in the upcoming weeks.
Splitter install on the stock chin spoiler coupled with a paint polish and another ceramic coating.
Man I bet that E85 power left a nice impression on the butt dyno! Everyone that can safely run E85 ... Usually does. Would if I could. But maybe with upgraded fuel pumps I can do a tune revision with Brad for E60. I can buy a barrel of E100 and mix it half and half with 93 E10. Make a nice race tune with it.
