Hi Guys, work in america, but project is in the uk, looking at doing a 3.5 gen2 HO swap into my van in the uk, going to use an American transit axle as well as you guys get LSD and the 9.75 axle, we don't, once swapped it will get a tune, hoping to get close to 600hp with the right bits, thinking i will keep it 10 speed, but at the back of my mind i want to make it manual, maybe mt82 if it can take the power, or go t56/tr6060, the mt82 is the better option, as its fitted to some vans like mine in the uk, so mounts and clutch should work fine, will be buying a salvage vehicle as the donor, prefer the new lincoln navigator because its got the same digital cluster hardware as the PP mustangs, so would try and fit that as well
