- RotM Winner
- Elite Member
- Boosted
- Logged
Update on upgrading to a dual nozzle setup. If you already have a single nozzle and are tuned for it(me) upgrading to dual nozzles doesn't do anything except throw off everything you're tuned for. I'm tuned with an M15 nozzle. If I back off to less I'll need a retune(s) or do more I'll need a retune(s) so basically if your tuner is happy with your meth spray/volume and pressure upgrading will only complicate things and is unnecessary....unless you just want some under the hood eye candy of two nozzles(me) then you'll need to change your nozzles. I have the Alky system so for me bc I'm tuned for an M15 nozzle I picked up an M5 and M10. So I'll have two nozzles but will spray the same so my tune is not affected. I already purchased my dual upgrade so I might as well install it.
Now some may need more volume...per tuner request and you could upgrade to two nozzles or just upgrade your single nozzle.
Big difference though if you're looking to get direct port...in which case I would assume you would want very small nozzles as you would have 6 at least...so you won't spray more than a single but you'll get perfect distribution like ZSHO has on that cute redhead!
And unless you want to mil the meth bungs down don't even bother. Just drill your own unless you have nozzles with a ton of threads like the SNOW nozzles.
FYI if you already have Alky nozzles and just want to swap them out you don't need to buy the hole nozzle assembly with the 90 degree fitting you can just buy the nozzle tips and washers for 15.99 each.
