A lot of you guys have asked for some specs on our tuners so here you go!
Livernois Motorsports Eco-boost tunes:
• Stage 1 - MyCal or SCT X-Cal 3 series: w/ transmission modifications only can use with 87 Octane.
• Stage 2 - MyCal or SCT X-Cal 3 series: w/ raised boost, increased timing, transmission- modifications with reduced torque management, and removed speed limiter Requires 91 or 93 octane fuel.
• Stage 3 - MyCal or SCT X-Cal 3 series: w/ raised boost, increased timing, transmission- modifications with less torque management than stage 2, removed speed limiter, and additional power over stage2 Requires 91 or 93 octane fuel.
• Stage 4 - MyCal or SCT X-Cal 3 series: w/ raised boost, increased timing, transmission- modifications with the least amount of torque management, removed speed limiter, and max power. Requires 91 or 93 octane.
• Stage 4+ - (Only compatible with MyCal series of tuners) is an improvement over stage 4 where it carries the boost out until the shiftpoint. All other versions of our tune mimic the factory boost curve and taper off at the higher RPM points. *Use at your own risk* we offer 91 and 93 octane tunes for this but they are aggressive. This is a more race oriented tune.
• Stage 5 - (Only Compatible with MyCal series of tuners) builds upon stage 4Plus, but is only compatible with the Livernois/Alky Controls Methanol system, 3-bar map, and using 100% pure race grade methanol (we use VP M-1). Requires 91 or 93 octane.
If you want to use any of these parts/ services in the future, only the MyCal tuners are compatible.
- Race gas tunes
- Livernois Billet Turbo Upgrade tuning
- Any "Custom" tuning
For the 2013+ Taurus, only the Non-Touch MyCal is compatible.
Please let us know if you have any questions or concerns, thanks -Brandon
