If you guys are doing this this on public roads, you're f**kin crazy. I had the MKS up around 100 on the highway, hilariously on the test drive, I doubt it's really flirted with triple digits too much since then though I do hope to change that when I'm finally able to get to the track.
Forza's a video game, while it's fun I sincerely doubt it's accurate. Someone with knowledge of the gear ratios should be able to do the math and figure out what a theoretical max speed would be if the car had enough power to maximize the gearing available. In theory non-PP cars, with their lower final drive, should have a higher maximum speed I believe.
