December 16, 2019, 05:13:58 AM
Author Topic: "How-To" PTU Fluid Exchange - glock-coma  (Read 475291 times)
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 12206
  • -Received: 4009
« on: December 21, 2013, 10:26:18 AM »
Originally posted by glock-coma
Changed PTU fluid
04-23-2013, 02:23 PM
I changed my PTU fluid this past weekend.
26,000 miles, It looked pretty bad. Replaced it with redline 75-w140.
Here's some pics.
I accessed the fill plug through the passenger side wheel well.
I used an impact driver with some 3/8" extension bars connected together
To remove/install the plug
PTU fluid at 26,000 miles. I was only able to remove about 13oz via oil extractor.
The cover plate must be pretty close to the gears. There was very little room to maneuver the siphon hose.
When I do this again, I'll do it from underneath the car. Seems to be enough access.
You can see the plug with the red thread sealant.
Here's a pic of the PTU part number.
Quote
04-23-2013, 10:00 PM
Originally posted by interceptor View Post
What does Ford recommend for a change interval? 100k? Hard to believe if it looks that bad after 26k.
According to ford it's a "lifetime fluid". I would guess that means factory warranty + 1 mile.
The fords repair manual it says it only needs to be changed if contaminated.
04-26-2013, 06:45 AM
I found this over @fordflex.net
"By the way fresh Motorcraft synthetic 75W-140 fluid is clear and it pours easily even when cold."
http://www.fordflex.net/forums/viewtopic.php?f=7&t=9334
04-27-2013, 12:40 PM
Here's the product data sheet.
It's $31.76 per quart from amazon.......it better be good
« Last Edit: July 07, 2017, 02:39:27 AM by SHOdded »
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 12206
  • -Received: 4009
Re: "How-To" PTU Fluid Exchange - glock-coma
« Reply #1 on: December 21, 2013, 10:37:30 AM »
Some additional info:
04-03-2013, 03:15 PM by racerx78
The PTU fluid is a 75w-140 GL5.
04-03-2013, 03:37 PM by Crash712us
Mighty mini vac with brake bleed kit is what I did.
04-03-2013, 03:46 PM by 83racecrew
It (Mityvac) puts a reservoir in front of the vac so you don't suck the fluid into the vac.
Like this http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_x_22973737-P_x_x
http://shop.advanceautoparts.com/p/mityvac-automotive-brake-bleeding-kit-mitmv8020/22973737-P
The fluid ends up in that little reservoir, before it would enter into the vacuum pump.
04-03-2013, 03:55 PM by Crash712us
Thank you racecrew. Here is a link of what you need.
Check this out on AMZN: OEM 25136 Vacuum Pump http://amzn.com/B000CMDPBM
04-03-2013, 06:26 PM by pacoflyer
What is the best method to get at the fill plug on the PTU? I hear removing RF wheel and inner fender? Is this correct?
04-03-2013, 06:32 PM by Crash712us
Paco either one will work brake bleeder kit isn't need for these pumps to suck out PTU. But the problem I do see with these is they are large, and you already said you don't have a lift or jack stands. The car will need to be level so not to over fill PTU, I did mine with the small hand pump as in the amazon link above. I had to empty the cup a couple times in my oil drain pan as it only holds about 8oz. I also had the car level on 4 jack stands. As for tool I don't remember the size of hex plug in PTU but use a couple 3/8" 9" extensions and ratchet and that gave me plenty of room to wrench the plug as my ratchet was just inside the passenger front wheel.
04-06-2013, 08:15 AM by Crash712us
Quote
Originally posted by bpd1151 View Post
What you guys are forgetting, is that the purchase of your pump, or vacuum contraption, or what have you......
That item alone is a one time cost.
Fluid ran me like $16 for the Royal Purple.
So your initial costs may be higher than desired, however, the long term benefit will be that you can perform this fluid swap whenever you chose to, from that point forward, and really only be out let's say $20 for fluid on the high end.
crash712us did his in his garage, so although having a lift would make it obviously a helluva lot easier, it's certainly not necessary.
Yes a lift would have made much easier, in fact not having a lift was the hardest part of the job. Having to squeeze my big under there and twist and contort my arms to do. Will be doing on my buddies lift from now on, will turn this hour long job into a 15min job.
04-12-2013, 03:04 AM by bpd1151
Quote
Originally posted by shomeda$ View Post
Does the rear end use the same fluid????
Differential gets 75w-90
PTU gets 75w-140
« Last Edit: January 11, 2017, 04:52:19 PM by SHOdded »
Offline mjhpadi
  • Elite Member
  • : Lewisburg, PA
  • Thank You
  • -Given: 341
  • -Received: 282
  • PADI IDC Instructor #17746
« Reply #2 on: December 21, 2013, 11:36:30 AM »
I had mine done by my dealer who also did the B&G service to the PTU...said the fluid didn't look great and that it was a good idea to have it changed.  My car had roughly 25,150 miles when the service was done in late November.
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 12206
  • -Received: 4009
« Reply #3 on: December 21, 2013, 12:57:13 PM »
Do you have an invoice or something that provides details of the B&G service for the PTU?  I'd be interested seeing as how that SHOULD get all the gunk out (with the usual caveat when NOT to "flush" something :) ).  TIA!
Offline BiGMaC
  • Forum Supporter!
  • RotM Winner
  • Elite Member
  • : Gilbert - SE Phoenix Metro Area
  • Thank You
  • -Given: 1155
  • -Received: 704
  • Ecobooster
« Reply #4 on: December 21, 2013, 03:14:42 PM »
Lotsa good info... including installing PTU drain plug in a sister thread at
http://www.ecoboostperformanceforum.com/index.php?topic=1704.0;topicseen
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 12206
  • -Received: 4009
« Reply #5 on: July 18, 2014, 01:43:19 PM »
If you are having difficulties accessing the plug or draining the fluid, you may find this thread useful:
http://www.ecoboostperformanceforum.com/index.php/topic,3360.0/topicseen.html
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 12206
  • -Received: 4009
« Reply #6 on: January 13, 2015, 07:59:14 PM »
2013 Service manual instructions kindly put up by a member on here:
308-07B Transfer Case — Power Transfer Unit (PTU)
Offline IHeartGroceries
  • Elite Member
  • Thank You
  • -Given: 0
  • -Received: 88
  • Ecobooster
« Reply #7 on: January 14, 2015, 10:38:56 AM »
^Wow, that's fantastic. Thanks to whoever shared that and thanks for linking it. I figured that is what'd it'd come to, with the cooler equipped cars (removing cat and temp sensor). Has anybody with a cooler attempted this service, using this guide from the shop manual?
I'll be doing once it warms a tad. Thinking March or so. I'll still be under 20K miles by then. And you can bet ill be sending a sample off for UOA. Should be pretty interesting.
Offline Zorin
  • Full Member
  • : Fort Walton Beach, FL
  • Thank You
  • -Given: 19
  • -Received: 12
  • Ecobooster
« Reply #8 on: January 14, 2015, 02:11:19 PM »
Could I use the same info on my 2011 or are the instructions different?
Thanks,
Z
2011PP, Kona Blue, 255/45/20 Michelin Pilot Super Sports, 3 Bar, 170 stat, LMS 93+Race Tune with ACES IV, Quantum Blue Fluids.
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 12206
  • -Received: 4009
« Reply #9 on: January 14, 2015, 05:07:31 PM »
AFAIK, you should be able to directly use the instructions in this HOW TO.  The cooling & temp sensor were added to the 2013+ models.
« Last Edit: August 18, 2015, 02:58:43 AM by SHOdded »
Offline curry67
  • Sr. Member
  • : Calgary, Alberta
  • Thank You
  • -Given: 23
  • -Received: 9
« Reply #10 on: May 12, 2015, 04:31:32 PM »
Ive never used b&g services before, ive found some volkswagen dealers and a fountain tire listed on the locate a dealer but are all these places like fountain tire any good at stuff like this?
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 12206
  • -Received: 4009
« Reply #11 on: October 22, 2015, 11:25:55 AM »
Changing out the fluid on a 13+ with the Performance Package
http://www.ecoboostperformanceforum.com/index.php/topic,4951.0.html
Offline Cruxin
  • Jr. Member
  • : Greater Milwaukee/Waukesha Area
  • Thank You
  • -Given: 12
  • -Received: 2
    • Titanium Dynamics
« Reply #12 on: October 23, 2015, 11:12:33 AM »
The pics for the OP are not working. Can you try re-linking?
Sean
Owner - Titanium Dynamics
"Ideal Performance, Without Compromise"
www.titaniumdynamics.com
Instagram: @titaniumdynamics
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 12206
  • -Received: 4009
« Reply #13 on: October 23, 2015, 11:44:39 AM »
Working on it now, seems to be systemwide ...
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 12206
  • -Received: 4009
« Reply #14 on: July 10, 2016, 01:07:12 PM »
Additional tips from a fluid change on an MKS
http://www.ecoboostperformanceforum.com/index.php?topic=6442
* Featured Topics
* Recent Topics
Re: 802SHO 2010 Build
by MrCRKLPOP | Today at 04:20:25 AM
Cleaned her up a little. man goals for my 11 nicely done...
Re: New Colorado MKS EB Owner
by SHOdded | Today at 01:49:44 AM
Welcome to the community!  Sounds very reasonable ... for now ......
Re: New member from northern Ohio
by SHOdded | Today at 01:47:02 AM
Welcome!  It might take a lot of TLC to patch this grievous deed ...
by bpd1151 | December 15, 2019, 05:04:12 PM
@J-Will......That's excellent to hear 1st hand experience with th...
Re: 2.0 control pack discontinued
by BEEFKING69 | December 14, 2019, 09:54:24 PM
Any updates on how this is holding out?...
by StealBlueSho | December 14, 2019, 07:49:29 PM
Nice addition!Meaty shoes from what I can tell, and paint looks to be ...
Re: Random thoughts for the day
by StealBlueSho | December 14, 2019, 02:30:17 PM
I think you should have decals made, rather large at that, and promine...
Re: PTU - Another one bites the dust
by avidmotion | December 14, 2019, 12:52:45 PM
Wonder if my pigtail will work as well......
Re: Fords at Carlisle 2020
by Leadfoot | December 13, 2019, 08:12:41 AM
I normally go every year on Friday and Saturday but never put a car in...
Unleashed December Specials, SCT / HPTuners + New Payment Options & Trade in / T
by tmcphail | December 12, 2019, 09:00:20 AM
Unleashed December Specials, SCT / HPTuners + New Payment Options &...
MOVED: Intercooler - Stock SHO Intercooler from 2014 SHO
by ZSHO | December 12, 2019, 07:18:40 AM
This topic has been moved to Parts for Sale or Wanted.https://www.ecob...
Re: South of Pittsburgh PA - MKS Ecoboost
by Ninja1320 | December 11, 2019, 04:08:51 PM
Thanks for the welcome everyone! I'll try to share any MKS specif...
Re: New from Louisiana
by 802SHO | December 10, 2019, 05:45:34 PM
Welcome and sweet Fusion Sport!  ...
Re: Looking for a aftermarket BOV for 2013 Taurus SHO
by derfdog15 | December 10, 2019, 06:45:13 AM
EcoPowerParts hot pipes with the Tial is the way to go. Better hotpipe...
Re: Not holding power in 1st gear in the cold?
by TopherSho | December 09, 2019, 08:54:07 PM
After a bump in tune revision it is much better.. still testing. ...
Back to top
