Torque Knock PID - may have some progress...
Started by ecoboostsho, November 08, 2013, 09:47:16 AM
ecoboostsho
I've been playing with the PID that we all believe is as follows (as confirmed by 4DR):
Manufacture ID: OEM_FORD
COM Level ID: CommLevel_ISO 14229
Comm Type ID: CAN_COMM
Category: Spark
16 Char Name: Knock Sensor
Description: Knock Sensor Retard
Address: 0x3ec
Address size: 2
Units: Degrees
Data Type: Int16
Binary Point: 9
Multiplier: 1
The actual Torque PID is 2203EC as you need to include the mode "22" to request information off the CAN bus.  If anyone is actually using this you do get some weird results just looking at the 'A' variable.  It will jump to 255 and count down at times and other times it will just register a 1 or 2...
It occurred to me that this is probably a two's complement (a way to represent negative numbers in Binary) when I was looking at the forscan.org program and they show "knock" as ranging from negative to positive.  I'm used to reading knock as an absolute from my GM days where if it was knocking it was just pulling timing.  I'm starting to think that this PID is knock but it will showing timing added or pulled due to knock or the lack thereof.
I then did some research and Torque actually supports "signed" numbers!
So for the equation in torque I used the following:
Signed(A)
I won't go in to a big discussion on signed numbers in binary here unless someone really wants me to - you can Google it obviously too.
I did this to see what I would get and sure enough I get a positive and negative number that makes a lot more sense.  Ranging from -5 to +3 so far for me.  I tried a more complicated formula to see if it was using both the A and B variable but it doesn't seem to really use 'B' for anything useful. The formula I used for that test was (Signed(A*256)+B)/8 ended up giving me the same result as the much simpler formula above so it only appears to be using the 'A' variable.
Now the next thing I've noticed is that all of the other scanning programs seem to measure knock in quarter degrees.  (0.25) which would imply there is a divide by 4 in the equation missing.
{Update - 8/8/2014  After further research here with others help I believe we have finally settled on the correct equation.}
By watching the knock PID in another Scan tool I am modifying the formula yet again.  I can't completely figure out the exact value but I am comfortable that the "A" variable will give you knock in 1/2 degree increments.  I suggest everyone updates their PID
So currently I am running with the following equation in Torque:
Signed(A)/2+(B/512)
It seems to be pretty close if not accurate.  Negative numbers right now actually indicate it is adding timing and positive numbers indicate the presence of some knock. Yes this seems somewhat counterintuitive but that is apparently how Ford designed it. (If it bugs you just put a '-' sign in front of the equation but then remember you put it there anytime you have a discussion on the forum) The noted ranges so far seem to go from -5 to +7...consensus on what is safe seems to vary and will probably depend on how modded you are ( A couple of degree running at 18 psi with aftermarket turbos probably wouldn't be great while it may not be a big deal on a relatively "normal" tune running lower boost/timing etc...)
Please include a screen shot of your setup, this would help many, after that I'll try and figure out how to get them out of torque and add them to a csv file so people can follow an easy process to add it.
As far as + and - it's due to the fact that the car will add timing if it doesn't see knock, it's kind of weird but it works that way.
Positive value = timing being pulled
Negative value = timing being ADDED
ecoboostsho
Will do.  Need to grab one from my car later...
ecoboostsho
Got the Screenshot!  I did some logging with Forscan and this is pretty close for the Positive numbers...the negative numbers in Torque seem to have additional resolution that I haven't figured out in the equation but this should give everyone a good indication of what is going on at WOT.  You shouldn't have more than a degree or maybe two of knock at WOT...anything higher would make me nervous although this car does seem to react very quickly to knock and seems to be good at saving itself...,
Please note the formula you should be using is -        Signed(A)/2
4 degrees and less is considered acceptable 5+ is starting to get worrisome. :)
ecoboostsho
Good to know. I hated knock on my GTP so I'm a bit conservative. :)
BigPelo
So I need to go in:
torque settings/Manage extra PIDs-Sensors/Add custom sensor
And then copy the info in your screenshot and voila?
Week-end family transporter: 2013 SHO tuxedo black, performance package, unleashed custom 94 octane tune, K&N Typhoon intake, 170F thermostat, 3 bar MAP sensor, SP534 spark plugs, 5000K HID Morimoto mini D2S projectors retrofit, tinted windows, Full LED lighting in and out, Eibach springs
Daily beater: 2002 WRX wagon swap JDM STi v7 20G'd
twnscrw13
Quote from: BigPelo on November 14, 2013, 04:14:17 PM
So I need to go in:
Yes, should work fine then. I mostly see "0" on mine. Sometimes I'll get an odd result like 63.8 or something like that.
2018 PP, blue. Sony, Navi. Stock.... For now.
ecoboostsho
You shouldn't get the 63.8 anymore if you are using the " signed" parameter above
twnscrw13
Quote from: ecoboostsho on November 14, 2013, 05:58:07 PM
I actually JUST changed to the 'signed' to the equation. It'll be nice not seeing that anymore! Thank you.
bigmoneycloser
Is this something "SHO" specific? Or can. Set this up on the 14 XSport?
Thx
2014 Explorer Sport 401A
ecoboostsho
Unless they changed the PID or something else on the  CANBUS I see no reason why this wouldn't work for you...
bigmoneycloser
When I went to the settings in torque
It warned me..." Saying be sure your info is accurate because adding something in here could turn on off features in vehicle???
Wow...
Quote from: bigmoneycloser on February 03, 2014, 10:31:06 AM
Wow...
Wow is right!  That's plain scary!   :hypo:  Could it corrupt a tune... or safety programming?  :hmmm:
ecoboostsho
That's a pretty standard disclaimer.  You won't be corrupting a tune with it.  You could accidentally update something (say unlocking your doors etc...) that wasn't intended.  I suppose it may shut the car off but this is only if you are typing random things in to this field - and as the app states you shouldn't do that.  There is relatively low risk in my opinion since mostly what you are doing is reading data not updating it...
