I would be careful just ordering bulbs from the numbers in the manual. I have not been able to find anything that looks like the reverse bulb in my car. Also, I know that when I went to do my bulbs in the interior, I could not use the same ones that Mike used in the how-to because they were too long. Seems that between my build and Mike's Ford had switched the fixtures and the bulbs were different. I would physically eyeball and measure the bulbs, so you get bulbs that will fit.
Lastly, when I tried to get LED's for just the taillight/stop bulb, I could not find one that would work correctly in the fixture...either they would not light or would light on full bright and not increase when the brake was applied. One more thing, if you are going with LED in the front side marker light, although it calls for an amber bulb, it really should be a clear bulb because the marker itself is colored, and although I did get amber I believe clear would show a bit brighter...and these are a bear to get at to change the bulbs. Just warning in advance.
