No start??? Wtf??????
Started by Flexthis2011EB, August 06, 2016, 06:24:39 PM
Flexthis2011EB
Weirdest thing happened. Driving down the highway i was curious to see if i had any other codes on my pcm other than bank 2 threshold, so i plugged my scanner in the obd2 port and all of a sudden all of the lights on the dash came on, batt, tpms, abs, service trac control message displayed, all this weird s***. So i pulled over, turned the car off and now cant restart it. Wont even crank. When i put key forward to ign, all those lights illuminate again along with blinking antitheft light. Also,  my scanner now wint link to my car abd my mileage data on dash has been erased. Does anyone know what the hell could gave happened? Im scared
2011 Ford Flex AWD Ecoboost 3.5l twinturbo
Did you remove the scanner, then try to restart?  Some OBD scanners will cause false issues.  May need to pull the neg battery cable for 30 min.
I have not attached a scanner mid-drive before, always at a stop.
Flexthis2011EB
30 min? No. I did for about 10 min. And yes, i unplugged then tried again. Nothing. Im getting it towed home now. I will try a full 30 min reset.
Could be a fault with the instrument cluster as well.  I believe it stores the PATS information, and if that is truly lost, that would explain the no-start condition.  Maybe it's just a fuse that blew.  I don't think the PCM is bricked ... yet.
Flexthis2011EB
Ive been reading about the steering angle sensor going bad? Would that cause a no start/crank? Or a sudden dash illumination freak out?
Did you try using a different key Fob to see if it starts?....battery could be low,try placing it in the tranceiver.  Z
Flexthis2011EB
Quote from: ZSHO on August 06, 2016, 07:45:27 PM
Did you try using a different key Fob to see if it starts?....battery could be low.  Z
I only have 1 fob. And the battery reads 12.3 volts. That should be enough to start the car, right?
Quote from: Flexthis2011EB on August 06, 2016, 07:52:55 PM
Try putting the key fob inside the transceiver to see if it starts,the car battery sounds sufficient.
Flexthis2011EB
Quote from: ZSHO on August 06, 2016, 08:12:47 PM
Wheres the transciever?
Quote from: Flexthis2011EB on August 06, 2016, 08:16:42 PM
Glovebox on the far right hand side,just insert your fob inside the slot,mines located on the center armrest console and see if that works . Z
Flexthis2011EB
Quote from: ZSHO on August 06, 2016, 08:36:22 PM
On the flex?  Im looking and see nothing to stick fob into
Sorry for the delay,1)try pressing the push button start(twice)to ignition mode and then move the shift selection gear throughout all the gears,park,drive ,reverse,etc and while in neutral try starting it to see if it starts,just so many things to consider like a neutral safety switch, brake pedal switch maybe or try checking the pcm fuse/relay and immobilizer fuse and keep us updated and also try getting a new key fob battery(2032).  Z
Flexthis2011EB
Quote from: ZSHO on August 06, 2016, 10:03:15 PM
Its ok. And theres no push start. Its a 2011 flex. But i will try everything else you mentioned. So far ive tried jumping battery,  resetting battery/pcm for over an hour, checked all fuses and relays, and even tried jumping starter from batt with key in ign. It wont turn over. Just cranks and cranks. If nothing happens tonight, i will be bringing to ford tomorrow.  Will keep u posted.
L1gerZero
Could always go the old fashioned way. Check to see if you have spark and fuel. find the schrader valve and see if there's any fuel pressure built up (not familiar with the vehicle to this point so correct me if i'm wrong) and pull coil and see if you are getting spark.
2017 Lincoln MKZ Black Label 3.0 AWD
What kind of OBD?
Sounds like it may have caused an issue.
I'd turn on the lights and pull the battery cable.
Let it sit for a while and reconnect.
