Here is how I performed AJP Turbo's wastegate mod on my 2013 XSport. Tuning still to be completed...
DISCLAIMER: The long term durability of the bonded joint in this write-up has not been established. Attempt at your own risk. Consider adding a 1.5" coupler with hose clamps as a back-up to the bonded joint.HARDWARE Tial MV-S Wastegate Kit (includes v-band flanges, springs, fittings, plugs, etc) SHO Intake Elbow with Noisemaker Port (FORD PN AA5Z-6F073-B) SHO TIP Sensor Screws (x2, FORD PN W506843-S439)1.5" OD Stainless Steel Elbow (KEGWORDS PN 44-731/1H)1/2" Corbin Clamps (x6, NAPA PN 705-1302)
1/4" Vacuum Hose, 6ft package (NAPA PN NBH H453)1/4" Vacuum Tee (NAPA PN CRB 2607)TOOLS/MISC J-B Weld Plastic BonderPermatex Ultra Copper Silicone Gasket Maker80-grit sandpaper
Brakleen (non-chlorinated)
Lint free cloth
Q-Tips
Dremel w/ Cut-off wheel (to cut off plastic molded hose clamps from SHO tube assembly)
Bench grider/file (to size stainless shoulder, as needed)
Vise (to hold stainless elbow for cutting)
Hacksaw/Band saw (to cut stainless elbow)
Welder (outsource, as necessary)
PART 1 - Hose Configuration (SHO vs XSport)SHO - Simple. Use your OE intake hose assembly after removing noisemaker.
XSport - From SHO assembly (AA5Z-6F073-B), cut off plastic molded hose clamp to remove 3" dia hose to CAC. OPTIONAL: Cut off plastic molded hose clamp on 2.5" hose (to TB). Remove the metal band clamp from the 3" portion of discarded hose and reinstall on the short section of hose. You will re-use the OE 3" hose from the CAC to the elbow.
PART 2 - Elbow Installation (same process for SHO or XSport)Test fit the stainless elbow in the noisemaker port. You want a VERY TIGHT fit. Skim the shoulder of the stainless elbow (bench grinder or file) as necessary to allow a very tight fit. With a DRY joint, you should be able to push/twist the elbow into place BY HAND. HINT: It will be much easier to do this with the plastic elbow removed from the vehicle.
With the stainless elbow installed in the elbow, reinstall into the vehicle, and tighten down hose connections. Be sure to confirm the TIP sensor clears the engine cover, when installed. NOTE: XSport owners will need new sensor screws! The XSport sensor screws are too long and will strip the thread pockets on the SHO elbow (ask me how I know).
Rotate the stainless elbow until it is pointing in the desired direction. Be sure to consider the size of the wastegate and the length of the v-band flanges, as these will need to be welded to the stainless elbow. Also consider the vacuum banjo fittings (from the Tial kit) and clearances to allow engine movement and hood closure.
Mark the stainless elbow and plastic noisemaker port to ensure proper alignment for adhesive later on. Mark the wastegate end of the stainless elbow where it needs to be cut.
Remove plastic elbow from vehicle. Confirm orienting marks are present, and remove the stainless elbow. Cut the stainless elbow at the desired angle. File or grind to a flat plane.
Weld v-band flanges to stainless elbow.
Note depth of shoulder protrusion into plastic elbow. Sand inside of plastic tube with 80-grit sand paper to roughen surface.
Clean scuffed noisemaker port AND the shoulder of the sainless elbow THOROUGHLY with a LINT FREE rag and solvent (I used non-chlorinated Brakleen).
Using a q-tip, apply a bead of Ultra Copper to the last 0.25" of the plastic elbow.
Mix 2-part urethane adhesive (I used JB Weld Plastic Bonder, Black). Apply to scuffed inside surface of the noisemaker port. Only a very thin layer is required - just enough to fill the scuffs. Too much will push out into the Ultra Copper sealant. Cut off the fuzzy end of a Q-tip leaving the paper shaft to apply the Plastic Bonder.
Insert the elbow 1/8"-1/4". Apply a light coating of the plastic bonder adhesive to the perimeter of the elbow. With a firm even pressure, press the stainless elbow into the noisemaker port with a slight twisting motion until it is fully seated and your marks are aligned.
Immediately wipe excess adhesive up with a paper towel (outside and inside). No solvent should be necessary. Leave to cure per your adhesive & gasket maker instructions.
Install wastegate, and hook up your boost reference.
DONE!
