Blowing off cap on throttle body servo drive?
Started by 91hybrid, November 07, 2014, 06:25:25 PM
91hybrid
Has anyone had problems with blowing off the gear cap on the side of the throttle body?  Mine keeps coming off. I've tried snapping it in but it doesn't hold.
Thoughts?
2014 SHO -PP, Unleashed Tuned, 3bar, Devils Own 100% meth, PPE catted down pipes, 3rd cat delete, Magnaflow 2.5" exhaust, 170 deg, NGK 7's plugs, hot pipes - White Platinum 401a
418 whp - 513 wlb/ft
non meth 13.11@103.6 (knock limited)
Meth pass 11.991@114.28
Haven't seen that one before.  You could try to glue it.
Just use a glue that's temp appropriate for the engine bay
2010 RCM non PP
K&N panel filter
sp534 @ 30
unleashed 93 performance+boost 3bar
more to come.....
91hybrid
I've never heard of it before either. I found it popped off laying under my throttle body so then I put it back on and the damn thing came off again. Only this time it fell underneath the damn intake manifold.
I was thinking of adhesive, but I don't understand what is making it come off. I'm not sure if boost pressure is filling that housing and popping it off or what is happening.
I wonder if there are any other seals internally or just the external seals.
MDesign Performance
It's raining out and now I'm tempted to check mine :|
A high-temp adhesive should be fine, you can get it at your local automotive store. It looks like it's held in by friction so I would probably just place a couple dots of adhesive around the perimeter and press firmly, leave it overnight to dry.
sales@mdesignperformance.com
www.mdesignperformance.com
Mine has been gone for years. Pretty sure it is getting blown off by boost pressure. As I have seen many other SHO's with that piece missing.
91hybrid
Well huh...now I know I'm not alone. Lol.
The cap has an o-ring and is held in by 4 small snap tabs in the middle.
The only thing I'm concerned about is getting grit in the servo mechanism over time. I couldn't feel any vacuum leaks or anything.
I'll look into an adhesive.
Another option is to drill a very tiny hole in it.
Curiosity got me to check mine. Still there.
Rich
dalum
Mine was under the engine cover when I got the car new.  Dealership put a whole new throttle body on.
2013 Non-PP SHO
91hybrid
I avoid dealerships like the plague...I'm sure I could warranty it, but I'll just try to seal it up like above.
wasinger3000
Mine is MIA now too... didn't happen till after meth. So it must be boost related.
13' GTCS, will be missed.
boostedbull
If it is boost that is blowing it off then that means boost is getting thru it. So with no cap you now have a boost leak.  Or am I missing something?
2012 SHO PP - Tuned by Torrie
12.8 @ 106  tune only
^I'm glad somebody finally said it. Lol! Air escaping from the TB or servo motor sounds like an abnormality which needs correction.
sunwolf
Wow I didn't even know I had one of those. Its been missing on mine since day 1.
2014 Taurus SHO Black Performance Pack LMS tune 3bar tstat downpipes
2008 BMW M6 Convertible SMG
2008 F-150 XLT 4x4 5.4L
2011 F-150 Ecoboost Crew Cab 4x4
2012 Lincoln Navigator L 4x4
